Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 25 Guests are viewing this topic.
Void
Quote from: gyulasun on November 11, 2017, 02:46:45 PM
Some hints: "The Watson machine was discharging 45000 uF (3 x 15000) capacitors charged to about 50 V, once a second into the batteries. ... J
If the caps were completely discharged every second (which they probably weren't if they were discharging into a battery),
and then fully recharged to 50V every second, it would work out to 56.25 Watts output to the batteries. If the capacitors were only being
partially discharged into the batteries every second, then the power output from the discharging caps would be less than 56.25 Watts.
Grumage
Quote from: citfta on November 11, 2017, 03:08:27 PM
Here is a link to a thread by someone that claims he was successful in building the Bedini/Watson machine.  He originally made an offer to me to let me come see it in operation.  Then he said he was moving.  After he got moved I tracked him down again but he said he was on the road all the time with a new job.  I never did get to see it in person.  I did not take time to go back through the whole thread but I believe there was a video or two of it operating.  And there were several pictures and drawings if I recall correctly.  Might be worth looking into his claims.
Hi Carroll.
It seems you forgot the link.   :)
A " 24 volt series wound aircraft starter motor ". Starter motors really " pull the juice " way beyond 12 Kw.... However I'm more inclined to the 12 Kv statement based upon the high voltage spikes I got when playing with Bedini's SSG.
Gearing was also mentioned, looking at the picture everything is " in line " could the motor have had a built in epicyclic gearbox?
Cheers Graham.
citfta
norman6538
Since John Bedini passed then is Jim Watson around?
As I understand John's original energizer it had 2 parts to the rotation cycle.
One to turn mechanically and the other to generate current. In the case of the school
girl motor which everybody got excited about it had 2 outputs 1. mechanical ie would
drive a fan and 2. electrical to charge the battery which was usually wasted power that
was used to effectively make the battery run the mechanical setup longer....
Then everybody went on to the window motor. I did not follow that one.
Maybe somebody else can comment on that.
But as for known overunity that can be demonstrated, the selection is slim to non.
However if you recall Naudin had a bingo fuel generator that looped - made gas that
ran the motor that ran the generator/welder that made the gas....
It behooves me that nobody picked up on the. To me its another lifter project of more
potential value.
Norman
tinman
Quote from: Erfinder on November 11, 2017, 03:03:38 PM
We are on the same page.....however.....in light of all the copying and pasting that was going on back in the day.....and this coupled to my own endeavours, I am inclined to think that it wasn't a typo...  in the right circuit, 12kv can work wonders...
15uF @ 12kv nets you a tad over 1k joules....
170uF @ 12kv nets you a tad over 12k joules.... yeah....
I think I am going to stick with 12kv Gylula......
I see problems with the original circuit/schematic being 12Kv
First problem--dumping 12Kv into a 12 or 24 volt battery?  :o
Second problem--12Kv will jump a gap of about 7mm,and so we would have one hell of a light show at the commutator switch.
Quoteon another note.... me thinks something's not quite right with the circuit....but that's me....
I see in the original black and white circuit,there is no FWBR across the energizer.
But there is one in the Bedini version.
Brad
