Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
#1687  : https://m.youtube.com/watch?v=d9Y9v6txZ9k   ;)
#1670:  rickfriedrich".....  I will present.... "
Give him the chance to explain correctly about his coil concept,function,efficiency !
After several years video presenting the members here should take the patience to wait for his new webside"in summer" and presentation/demonstration !
hartiberlin
The skeptics may have got it wrong.
In this thread it is not going so much about real OU, but the best usage of lead acid batteries with such circuits as Rick´s one and getting the most usefull energy out of it.
So as BauDirEnergie already said, we just see, that the produced Watthours are bigger
than the Start-Energy put into the battery, before the test was started...
With these resonance circuits you can just extract more out of the batteries as the "one-wire"setup from the BackEMF-Line to the second batteries Positive terminal works just like a standing wave
and if you put in there some additional coils or better transformers there, you can extract a lot of energy there on their secondary output of the transformers.
Also the counter EMF that these transformers generate goes back to the driver circuit and really reduces pretty much the input current...
So all in all we probably have here a violation of the Lentz law and a better usage of the inputted energy...
So if it does not work with capacitors or supercaps, that is a different circuit and we should use that.with what it was shown to run... lol...
Anyway, if we just have longer lasting batteries on our loads, that is really great...
so instead of running a 3 Watts LED light on a 12 Volts 7 Amphour=84 Wh lead acid battery for 28 hours,
you now can now run it for 100 hours,
that would be a great thing and a good circuit to use !
Don´t you agree ??
So this is probably imho the main focus, what Rick wants to show us, as I understand it....
Okay, if the battery is damaged faster than normal, due to these effects, must still be researched..but so far they seems to last quite well...
Regards, Stefan.
Gear
Quote from: baudirenergie on July 29, 2019, 04:38:10 PM
Very nice. I was blind, but had hope that all this Videos from Rick ends in positive results. It is a barrier for people, that only would greedy grasp something without want to invest some time. That informations are not good for rough people, I think. I can see it on your last comment to Rick..wow!
Why did you make a big deal about measurement. It is very easy to do it very accurate via Watt hour meter (sorry, don't know the correct word in english, it is a DC Watt hour measurement Tool).
First you load your primary battery to maximum and unload it over the Wh-Meter. Now, you know your Wh in your battery or battery bank. Reload it to the same Cutoff Voltage and start your system. All other batteries (for example secondary battery bank) should be completly empty.
After your run you can unload all batteries in your system over the Wh-Meter and can prove for yourself, if your system is over- or underunity. Simply compare the total Wh after your run with the total Wh that you have measured before.
You are good guy and trust too much. In every circuit you must measure input power and load power.
Otherwise you will be misslead into falxe thing.
I wont go into deep of topic. Lots of guys here done it and saw mistakes.
Nobody here is telling you that as a joke. They also been misslead many times and learned the lesson.
Measure input, output, thats the only way.
Dont trust nobody until you do your measurements.
Most realible measurement is transient one. You must have scope, voltage and current probe and ability to make math on scope.
Every other method sometimes can lead to nowhere.
There is no magic negative power which feeds lots of load. No. You measure how much your load consume. That is correct way.
Always measure! It will also show your mistakes as well!
I dont mean to discourage you.! Always take the measures the proper way!
Sorry to dissapoint you about Rick.
gyulasun
Quote from: hartiberlin on July 29, 2019, 05:22:26 PM
Don´t you agree ??
But Stefan, Rick clearly stated :
Quote from: rickfriedrich on June 15, 2019, 12:01:38 PM
Now if we look carefully at your position in these matters with your insistence about measuring LEDs, and your questions to me in that respect, we find that you now show your skepticism bent. Notice I answered your point in that measurement is 0.5W each (it is sometimes 3W when I put the ferrite coil in the transmitter, which also brings down the input to 0.5W) with larger LEDs. There were 15 total as I had 4 smaller coils with larger bulbs as well (one under the table and 4 at the top at one point--10 big coils, 4 smaller, and 1 on a ferrite rod). There were 75 small coils with LEDs totaling over 2W. So we have at least 8W of measured power with 0.75W or less input. All 18 people at the meeting could see that I could continue to add more and more coils with loads which only brought the input down.
So he claimed COP > 10 performance between the resonant TX and RX circuits.
Gyula
WhatIsIt
Stefan,
One thing is nott clear to me.
If you believe Rick so much, why you did not give him OU prize.????
Or this whole thing was just a show?
What about Mr. Itsu?
