Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
Void
Quote from: tinman on November 22, 2017, 06:04:51 PM
Hi Void.
As stated in my post,i was using my power supply,which is a smooth DC output,set at 15 volts to charge the cap.
Still working on the energizer.
Hi Brad. I was asking about what you meant by your 'pulse charger', but no worries...
I thought maybe you meant you were driving the motor from your power supply. :D
I guess maybe you mean just your controller circuit connected to your relay.
Hi Grum: (I left the @ symbol off for you. :) ) It's looking good. :)
All the best...
tinman
[author=Void link=topic=17491.msg513407#msg513407 date=1511395050]
Quote\
Ah,ok
Sorry,i should have been a little clearer.
But anyway,i was just driving the circuit ,and charging the cap with my PS,then dumping the cap into the battery-no motor or energizer at this stage.
As i was using mechanical relays,the arcing at the relay contacts may be what we are seeing.
But as the frequency is close to what Tom Bearden states,either it is in the battery it self,or they too were seeing the arc frequency across the battery.
But the battery charged quick,and after placing a good resistive load across it,it is clear that it was a good heavy charge,and not some surface charge.
Will be doing some further charge and load testing as i go along.
Brad
Void
Quote from: tinman on November 22, 2017, 11:44:56 PM
Brad
Hi Brad. Yeah the arcing from the relay contacts would likely generate some spikey looking waveforms of some type, but that
should show in bursts right at the points where the relay switching occurs.
If that high frequency noise waveform you showed on your scope is coming from the battery, that would really be something.
That's great that the cap pulsing put a good charge on the battery. That is a very good start. :)
All the best...
ramset
the reference to recent "bets" here made me take another look at a Post On EF the other day
It is suggested by no less an authority than Andrija Puharich that are hero Tesla was also 'Nutless' perhaps to remove sexual 'urges' and so concentrate on his research ?
I often wonder if some readers and contributers to energetics I would be very happy to name might like to urgently consider the same procedure ? (in the interests of science)
https://vimeo.com/4935037
end Quote
I have removed the posters Name [since he removed the post ,but it was copied by another member]
careful with the bets...... :o
Thanks Grandma
AlienGrey
Watch this if you think its all crud !
But don't get up set by this guys first comments.
https://www.youtube.com/watch?v=SVD1dIGcmXk
