Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
hartiberlin
Quote from: AlienGrey on August 19, 2019, 07:25:22 PM
Stefan please don't be offended here but if that is true why is the flyback diode the other way round?  ;D
http://www.learnabout-electronics.org/ac_theory/images/Protection-Diode.gif
This is the only around the diode works, otherwise if the polarity would be the other way around of the diode,the flyback diode would conduct the current instead of going through the coil...
So this is the only way it works and it shows that the voltage is reversing, so then the diode is conductingand cancels the high voltage away on the coil and the current in the coil does not reverse...
Regards, Stefan.
Raycathode
t's a nice try but for it to be any use you need  to stop the BEMF going back into the coil winding as it would keep ringing until exhausted and is all you can do with that energy is pump it back into the supply where it came from but because of its polarity it was generated with will always be less than it's supply.
But if you wanted OU BEMF you wouldn't do it like that.
However as with a relay coil or motor usually that doesn't matter.
PS for what the been done to OU you might as well erase my log in as it's utterly useless value now. bye!
Regards AG
Amazing! This post was dated the 19th and 20th of August How come it has taken till now the 7th of September to appear?
I haven't seen this post appear prior to days date and AG sounds really PISSED off to say the leased  ;D ;D so one must ask when will the great 2019 moderation war end Chet refers to in ((((
Offline ramset
    Hero Member
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #21647 on: September 06, 2019, 08:09:44 PM »
we have a lot less peeps here since the "RF" situation ......the great moderation's of 2019 ,have left a Void.[ a big empty space here where builders use to be.
Chet K )))))
Anyway, you are both appear to be talking about different things one about protecting the transistor and the other about making use of the flyback pulse.
PS Stefan is right and as an afterthought your collecting a positive impulse according to JB you always end up with less than what was originally used so no gain here and since this is an OU forum a far different approach would be required to my way of thinking.
Raymondo
mrzlica
Hi,
did anybody visit Ricks meeting? Is the kit working...
Lots of people from this forum claim it that is all fake.
Maybe somebody was there and can give us a quick briefing, is
it worthwhile?
br
ramset
Wellthis is a very touchy subject here ,and as of this writing ...it seems its still all a big secret ?
as nobody I am aware of can reproduce OU results [or share them]?
One open source inventor in particular spent 3 months trying to no avail... and if he had a sniff of success
there would have been resources spent towards this Indiana show .
would be good if any persons [AKing21 ??} could share something with a happy result ?or is Open sourcing forbidden ?
measuring too ?
to be honest one member did ask ,and he was making some suggestions as to why there was failure here ,i was not understanding his Direction but it went back to Anslie and a wrong turn ?? [her COP 17 claim] something about magnetic ??
I will call him back for more explanation and perhaps a fresh look ...and maybe Stefan can ask his friend if he had success with RF claim he was building.
Thanks Grandma
carbon sugar
Hola chicos, yo soy nuevo por aquí y no pretendo generar polémica ni nada por el estilo, tengo varios experimentos realizados y les puedo asegurar que la energía libre existe, energía libre porque somos dueños de esa energía, dueños y no dueños, si somos dueños no seria libre je, he cargado baterías con back emf, usado motores durante meses sin que se descarguen las baterías, he cargado celulares, baterías y computadoras con mi bobina POE vortex, meti mi bobina POE vortex en un cloud buster (maquina de lluvia) y después de tres días de meterle frecuencia, salieron flotando 7 u 8 bolas de plasma de mi jardín, a unos pocos metros de mi cabeza, 3 metros de distancia, es como decir que la tierra donde vivimos no es libre, que no es nuestra, es tan nuestra como no lo es, tenemos responsabilidad de las cosas, que el sistema durante años, cientos de años se adueña de todo, eso es otra cosa, el sistema no nos hace libres, por eso nuestro pensamiento de las cosas, los artefactos se desgastan y eso produce que no puedan usarse infinitamente, si hay finito, hay infinito, vengo estudiando medicina china, nutrición naturista, educación física, tecnología, agricultura, de todo, y ahora electrónica, he visto mucho, y también he tenido experiencias de todo tipo, vivimos en un océano de frecuencias, vivimos en un campo magnético, ese campo magnético es lo estático (seria la cancha de fútbol), a partir de ese campo magnético comienza el flujo de energía radiante, esa es la parte dinámica (serian los jugadores de fútbol), siempre va a estar un polo y el otro, para que se junten en un equilibrio, ese equilibrio es el máximo punto de energía, eso es lo verde, la naturaleza, tenemos que romper nuestras estructuras mentales, liberar los pensamientos, o empezar por ahí, podría seguir contando muchas mas experiencias pero el mensaje se vuelve aburrido, es hora de empezar a dar el conocimiento, darlo sin costo, abrazo para todos
