Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
tinman
OK,found the claim--oh,and the books you need to buy to make it work lol  ::)
Thirty years ago at the Tesla Symposium in Colorado Springs, Jim Watson demonstrated a very large scale machine based on John Bedini's 1984 Free Energy Generator.
At the conference, the machine was running and producing a lot of mechanical work, but what was amazing is that it kept itself charged up the whole time!
It had a large three foot diameter flywheel that weighed about 800 pounds attached to an aircraft starter motor, which was battery-powered. The generator section charged a bunch of coils like a magneto, which sent this back to the battery running the machine.
Below is a diagram that John Bedini showed for his smaller prototype.
Between this image and some other diagrams – Jim Watson who had no electrical engineering background make it work.
Over the years, many people have tried and failed at replicating these claims. Very soon, we are releasing Bedini SG – The Complete Advanced Handbook. Included in this highly anticipated release are details about the Watson Machine that nobody has figured out in the last 30 years. And, the keys to making it work have been sitting right there in plain site!
There are already two books: Bedini SG – The Complete Beginner's Handbook and Bedini SG – The Complete Intermediate Handbook. These are an absolute requirement to have in order to understand the basic working principles of self-regenerative energizers. And with the Advanced book coming, it will take everyone's experiments and results to the next level!
So,all those that bought the !The Complete Advanced Handbook! ,should now have working machine's,where the battery remains charged,while the motor continue's to do mechanical work.
Source
https://emediapress.com/2014/10/21/watson-machine/
tinman
Ok,so after much hunting,i found a link to a thread at EF,that is about the energizer.
From Peter Lindermann him self,which confirms some of my earlier thoughts.
Quote:
Hi Guys,
Thought I'd drop in and share a few things.
There is another interesting feature of the Watson Machine that is usually overlooked, and that is the motor. The salvaged aircraft starter/generator unit was essentially a system that had a wound field and a wound rotor, with a brush commutator. It was probably SERIES WOUND. This means that when the motor is offered electric current from the battery, it will produce bursts of TORQUE. It also means that when the motor is disconnected from the battery, it will produce NO back EMF and NO DRAG except for the brush friction.
If you attempt to use a DC motor with a permanent magnet field in this machine, it won't work, because these motors ALWAYS produce reverse currents into the shorted turns of the rotor windings, and therefore, always produce DRAG when not connected to a power supply! You can see this behavior quite easily when you try to spin the shaft. A permanent magnet field DC motor will NOT free wheel when disconnected from power. They stop very quickly due to their internal short circuit on the rotor!
For those of you who have seen my DVD Electric Motor Secrets, you may also understand that if this motor/flywheel system is run at a speed that is significantly near the top speed of the motor for its excitation voltage, the current draw will be greatly reduced, because the internal back EMF of the motor will be approaching maximum. There are other subtleties to this aspect of the machine that only become apparent after significant experimentation with motors.
With the permanent magnet induced, inductive collapse "energizer" driving into a capacitor, the back EMF drag of the generator section drops to a very low value because the system is encouraged to produce VOLTAGE instead of current. Current production is the ONLY aspect of electricity that causes DRAG according to Lenz Law, not voltage.
This is the first machine that Bedini developed for the charging of a battery from a capacitor dump. Its a brilliant little arrangement because the capacitor never drops below the battery voltage, so when it is disconnected from the battery, 100% of the energy it receives from the "energizer" is added to the capacitor at a voltage ABOVE the battery voltage. So, the system can produce 100% of its energy at reduced back EMF and make ALL of it available to the battery.
With the flywheel storing the torque, produced by the motor pulses and consumed by the "current production" of the energizer, the "window" for understanding HOW the machine can go OU is revealed. This machine cannot work without a proportional flywheel and a good, low friction bearing system.
The secret of the machine is in "managing" the back EMF production in both the motor and the generator. The motor MUST be able to operate in a pure "free wheel mode" in-between the torque pulses it contributes. The energizer MUST charge into a capacitor so its output is biased toward VOLTAGE production and away from current. This reduces the back EMF drag (reverse motoring effect) it produces.
When all of the components are proportional (tuned) and the system gets up to operational speed, the losses go to minimum and the COP goes above 1 and the battery starts charging.
So,i have highlighted key points.
1-we need a series or parallel wound DC motor--not a PM DC motor--Peter says-->probably SERIES WOUND.
As i stated to Grum,and confirmed by PL-->understand that if this motor/flywheel system is run at a speed that is significantly near the top speed of the motor for its excitation voltage, the current draw will be greatly reduced, because the internal back EMF of the motor will be approaching maximum
No problem,i have many starter motors  ;)
2-,we need high voltage output from the energizer--Erfinder seems to be on track there.
3-we do need a cap/cap bank-as i added into the schematic.
Bit i dont see or understand in regards to the provided schematic--->Quote: With the permanent magnet induced, inductive collapse "energizer"
Where is this inductive collapse mechanism in the schematic ?,as all i see is the gen coils going straight to a FWBR  ???
And yes--we have the claim by PL
Quote: the losses go to minimum and the COP goes above 1
Source
http://www.energeticforum.com/renewable-energy/3927-watson-machine.html#post48882
Brad
Quote from: stupify12 on November 11, 2017, 08:13:19 PM
The proven OU device here is the FLYWHEEL, but nobody seems to check i posted above on this page.  We might need Buck-Boost converter on that HV capacitor being charge to convert it to pure amperage(12v or 24v) that can drive the motor when switch over. Chas Campbell was one of the example, so many have already uploaded the so called FLYWHEEL Free Energy Generator on the Youtube.
Will
No, FLYWHEELs are energy _storage_ devices. You get out what you put in, minus losses. Do you think a Bank is a money source? No... you get out what you put in, or you have to pay back more than you take out in loans.
None of the alleged flywheel Free Energy Generator devices actually work to give more out than in.
Brad -- you and I both know that Lindeman's claims are just that: claims, full of hot air, never demonstrated to be truly OU by anyone who has ever tried them and certainly never self-looped or daisy-chained. I don't think he'd recognize a 24 volt aircraft starter motor if he woke up next to one some morning.
But since this topic is here and talking about _unproven_ things and things which have already been proven false, I've decided to share my EEEE apparatus design here.
Most of this system has already been proven to work.  8)
profitis
"And with the Advanced book coming, it
next level!"
Peel that onion DOWN bro
