Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
tomd
As I understand it these coils are used to demonstrate some of the principles underlying some of Don Smith's devices. In particular I'm thinking of the device having a loosely coupled primary and secondary Tesla coil surrounded wirelessly by 3 coils in resonance with the secondary.
In his 1994 video Don said in reference to series resonance "Almost all the things that go on here will be essentially in parallel because when you put them in series you get a degradation."
gyulasun
Hi tomd,
Member aking posted this: https://overunity.com/17491/confirmation-of-ou-devices-and-claims/msg533791/#msg533791
What Don did demonstrate was an off the shelf inverter driving a fan from a 12V battery and when asked why he did not show the two other boards hooked up into his setup, he answered he also had 24 hours a day like anyone else...
In fact he never showed his HV boards operating and producing the kiloWatts output.
Gyula
AlienGrey
Quote from: benfr on April 24, 2019, 05:27:32 AM
Hello Guys !
Why not take a simple working recipe and build from there ?
Rick Friedrich has shown a great tool of how to produce easy overunity on this video :https://www.youtube.com/watch?v=18kOGVfkoik
how to produce a multiplication of voltage , or amperage, or both.
How is that done and possible ?
Well, I am going to help you build one in a single hour's time below.
What you can also do, to be safely and thoroughly taught by Mr Friedrich, is get his "kit" : the "resonant inductive coupler kit" that comes with a 3 hours video to show you what is OU out of the simplest recipe on earth.
For our friends in any other country in the world, who do not have 100 USD to spend, and who may have a bit of cables , and can spend a few dollars in a few electronic parts, I am going to show you what is shown in the RICK kit, without departing, as said Tesla, from the interest of buying it.
I. You will build 3 coils which are as follows :
- 2,5 centimeter diameter (a plumber plastic should be around this and work even at 3 or 4 centimeter).
- 0.5 mm to 2 mm width for the wire
- 54 to 57 turns.
inductance : around 157 uF.
get 3 "100 pF" capacitors.
II. put all those in series :
x capacitor>coil>capacitor>coil>capacitor>coil y
III. send a SQUARE frequency of 863 KHZ at 11 to 15 volts at x and y points.
the frequency can be approximately deduced from well established formulaes, for instance :
https://goodcalculators.com/resonant-frequency-calculator/
IV. put a 100 V bulb anywhere across several points in this circuit, for instance on x and y .
it lights brigthly : voltage has been mutiplied by a factor of around X7, so a Q=7, so a 700% factor multiplier for voltage.
V. remark : the amperage stays the same.
You may now Thank Rick Friedrich for creating this kit in hommage to Don Smith, which I highly recommend to buy (100 USD).
Key words : Tesla, resonance , Tesla lecture 1893, high frequency, Rick Friedrich, resonance coupling, overunity, voltage multiplication, amperage multiplication.
AlienGrey
'i highlighted it in green I was trying to find out how Itsu got his 90 deg phase shift.
Then found that and thought that can't be right. then tried to reverse logic what that Rick F
was up to and got really confused.
Feel free to delete both posts  :)
forest
Make resonant circuit with parametric pumping input frequency and the method of converting output to very high frequency. That way OU is real I think.
https://hackaday.com/2019/04/26/parametric-amplifiers-and-varactors/
I spotted this effect in 2005 with the room filled with electrostatic response from all metals. The proper grounding then makes current flow outside of the wires. In fact Tesla said it in plain sight in his interview. I believe Barbosa and Leal perfected Tesla method but we won't know due to cryptic patent text (like always).
Quote"That was in 1891, prior to my going to England to lecture before the scientific societies there, the Royal Institution and the Institution of Electrical Engineers.   I had a wire run out through the window, and placed on the roof all sorts of devices to constitute this capacity [shown in the diagrams as an elevated square].   The first step was to connect this alternator [shown in the diagrams as a circle] with one terminal to the water pipe system and the other end to the antenna.   I had already proved in my lecture at Columbia College that I could transmit energy through one wire; therefore, I was prepared to find that a current of considerable strength could be passed through this wire here [connecting the alternator to the elevated capacitor], although it was insulated.   My idea at that time was that I would disturb the electrical equilibrium in the nearby portions of the earth, and the equilibrium being disturbed, this could then be utilized to bring into operation in any way some instrument.   That was what we would now call, simply, impressing forced vibrations of very high frequency on an antenna.   We have introduced the term "antenna" since that time. . . ."
[/font][/size]
