Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
gyulasun
Vortex1,
Itsu made already a correction on the frequency in his post #349,  line 4.
Vortex1
Quote from: gyulasun on May 02, 2019, 09:49:39 AM
Vortex1,
And so he has. I  apparently missed seeing the correction. I did an edit on my post in that regard. Thank you.
Forgive me for asking... but is there some reason you aren't using autoresonating drivers for your transmitters? A phase-locked loop, or an E-field antenna trigger, or even an autoresonating LC tank like a Royer or Mazilli oscillator? It seems rather strange to me to be using a FG for the primary clock, unless there is something really specific about a particular frequency that is being tested -- and if that's the case you should be using a crystal oscillator. If you really start getting good high voltage performance you may find your function generator doesn't like it very much. (By good HV I mean tens of kV at least. A couple kV is child's play when you are talking about Tesla's systems.)
But carry on, have fun. But you might actually like to view my wireless power transmission videos, especially the last few TinselKoil vids. I'm not selling anything!
itsu
I completed the 2th RX and added the gate driver (IXDD614) on the TX, see picture.
With 9V on the driver and tuned to resonance (1.627Mhz now) with the FG (3Vpp pulsed DC 50% duty cycle)
i have the below shown signals see screenshot.
Blue is the input to the gate driver
Purple is the output from the gate driver
Yellow is the signal across the series cap.
I guess some filtering needs to be done.
The tuning with 2 Receivers is already tricky, so let alone with 5.
Itsu
Heh... at that frequency you are most probably operating in a pure EM mode, so you don't have to worry about "real HV". You may find that you can achieve "supernova mode" close coupling that does not result in a 1/r2 falloff with distance (to a certain limit.) Your receivers seem to be essentially the same as used in my system. The main difference is that I use coils of much lower inductance (and hence less power-wasting in ohmic resistance) and autoresonating drivers, in this case a Royer oscillator:
https://www.youtube.com/watch?v=9x2YfA9LU5s
