Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
benfr
Congrats itsu ! I hope this is the beginning of Joy :D
Two remarks : do try to moderate the distance of the secondary coils from the big coil : they should be between "close" and "distant" : this location allows not to detune the main one. Detuning the main coil from the resonant point you found is something you want to avoid.
2. it's very interesting how you show that the individual consumption of the satellite coils go lower and lower as the multi body configuration expands. What is the limit of this ? Zero consumption ?...
3. try to put your satellite coils at the level of the top of the big coil ! (on a piece of non disturbating magnetic field, such as wood or pvc) : any difference ? ...
itsu
Thanks for the congrats, allthough i am unsure for what.
As soon as a satellite coil draws current (which is way before its led goes on), detuning of
the big coil takes place.
So avoiding that is almost impossible.
Well, it seems the more satellites you add, the less power remains left for all of them, but at a certian point
the leds go off, but still they use power, so its hard to predict what will happen at the end.
I did change the height of the satellite coils, best result is half way up the big coil as shown.
But...., my satellite coils are not correctly build (they are to long and not wide enough).
Also the winding direction of the big coil is wrong (CCW) compared to the satellite coils (CW), so
i am making some new satellite coils (ccw) of the correct size (6cm former, 0.7mm wire, 52 turns).
Perhaps that makes the difference.
Itsu
NickZ
   Itsu:   You may want to try a couple of your Dr. Stiffler "diode loops" and leds on the big coil, instead. They might take less input from the big coil to light brightly. Blindingly bright. Other wise you may get stuck at the 2.6 volts level, which will not light the leds to full brightness. Each additional load of leds will share the input source, and is why the voltage drops. Not because the more leds are lit the load on the input drops. It drops because they are all sharing the input source. As you know, but other guys may not know that.   It would seam that up to now All free energy or OU devices they we've tried, are nothing more than inefficient bottle necks, compared to the input source. Hopefully we can do something about that.
seaad
Can anyone explain to me why LEDs are always used as load (resistors) in all these threads /discussion groups about OU through the years.
Is it so that that is the best way to prolonge the threads duration (amount of words written) in an optimum way?
Whats wrong with resistors??
Arne
AlienGrey
Itsu and Gyulasun, You're going to luv this one! in the Ruslan Akula 'yoke' this device has two output windings,
both feed the grenade device one with a parallel capacitor and the other with a series cap so one would expect
the one winding to be out of phase with the other but I can't get a phase shift with an oscillation feed from the 'yoke'.
Obviously, the 'yoke has it's own inductance and isn't a Sig Gen, any ideas? the yoke in my test windings are
Grenade                                                           Yoke
inductor winding                        138uhry  ------- 28 turn winding                        7.4mhry
none inductive 6 layers winding  268uhry -------   4 turn winding                         0.22mhry
What we need to find is how to work out of find the correct capacitor values
As Wesley also used this type of circuit as an energy boost we need to test this circuit as it could be of good use if proven! and well on the thread!  ;D
Regards AG
