Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
0 Members and 101 Guests are viewing this topic.
a.king21
Just found this online.  I should sue the guy for copyright infringement. lol. It's from several years ago.......
Now surely you get it... don't you??
(https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/129271/image//)
rickfriedrich
AG,
Why did you tell us that we may be interested in the Bedini video and then include a disinfo video before it? Both of these are revealing major lies. One that lies about my fan kit and the otheris  Bedini lying.
Is this inclusion of the first video an attempt to try and discredit me? Your starting the video at 116s shows where the guy is showing the voltage of one coil output of 1-2V. This is normal. This guy is a liar because the circuit does not ever use the coils as generator outputs as that point in the video implies. No one on the forums would even try to say that. Everyone can see a huge spike, but he lies and says it is only 2V output. The output is in relation to the motor action and not a generator action. The electrical impulsing of the coils is what causes the output charging of cap or light or battery. The magnet impulsing of the coils as he shows does not cause the charging, and results only in producing 1-2V. This is what in fact is used to create the trigger coil turn on only. But once the motor starts then the trigger coil in a bifilar arrangement (which is a more advanced option with resulting higher output but more difficult to wind/assemble) becomes a much higher voltage (which is another place where free energy is produced in the circuit--which this video does not do).
Secondly, the cap being charged in the video is also a lie because the kit capacitor charges up to high voltage very fast. And when we pulse the cap we charge the battery about as fast as the input battery discharges. He doesn't show either a battery running the fan or charging. It is impossible for the capacitor to stay at 1V or less. It goes up past 200V very fast. The cap pulser actually pulses the battery about 1V average above battery voltage.
Of course this disinformation agent correctly calculated that people would just trust what he says without verifying anything. So you can see that 6 times as many people liked his fake news video. And this is what happens right here on this forum and all the forums. This is exactly why I say you cannot prove anything over the internet and with video or pictures. So why would someone do this? They knew they were lying and misleading everyone. What does that tell everyone here? Why would someone go to the trouble to try and deceive 4 million people? So why are you promoting this video that is obviously disinformation? Are you trying to discredit my claim about the fan kits or me because I mentioned it? Instead now people can see this is an obvious disinfo video as at least 7600 people could see there. These attacks are old news. I won these debates the first 2 years of doing this and I answered every question and objection. Eventually the skeptics changed their level of objection and requirements and merely insisted that there be at least 3 times the output. So I showed that with bigger batteries being charged and another form of the third stage process. After that we really didn't find anyone disbelieving these claims because thousands of people all around the world were doing this. And the fan kit was so popular several others took the credit for my kit. One student of mine even sells it in violation of my friendship.
This is what I wrote in his comments: "If you look at my actual instructions on this you will see that you did not connect the wires right. Everyone knows that the output will be at least 300V and the capacitor will charge up to high voltage very fast. The battery will also charge up around the rate of the discharging battery. I have swapped the two batteries around for years. You have not even used batteries. This video is a lie therefore."
This setup in this video, which is misrepresented and purposely not showing it running the way it runs, is one of about 5 common ways. The first was to make two coils motor coils and two trigger coils. This is what Bedini did with the tape motor drive which is similar to the brushless fan motors. This was not a good use of the coils. So at first I made the all four of the coils motor coils and I unwound one coil and rewound it bifilar with a smaller trigger wire with it. It was rather hard to do that. Then I had 4 transistors so that the motor was about the same as original instead of wasting the two coils as trigger coils. This gives the true results of my claims just like the other kits with the trigger coil. The third way was to merely replace one motor coil and make it a trigger coil while you had three motor coils with transistors. With all these ways you have to realize that every other coil is reversed from the ones beside it. The guy in the video did not do the proper coil arrangement. The next way is to use the actual circuit and merely change around the one diode and add two diodes on the collector terminals of the two transistors. These go to the charging battery. Now the motor runs exactly like it always runs but charges a battery also. This doesn't give as good results because the rate of change is slow. So the fifth way is to change out the transistors to one mosfet and add the fast gate driver and use the existing hall (which sometimes needs to be replace as it often is a latching hall). Now the circuit is more efficient and the charging is much better, and more like my dualpole energizers. In all these cases the bigger the battery the more the output over time. You can also do the third stage of the Loving Paths process with this as well.
Quote from: AlienGrey on June 28, 2019, 03:51:37 PM
You guys might be interested in this John Badini video
https://www.youtube.com/watch?v=g4tO0kBOzqk&t=116s
https://www.youtube.com/watch?v=xtGz4QHJ0e4
rickfriedrich
Not following your point here? Get what? that he copied your page or what the circuit is showing?
Quote from: a.king21 on June 28, 2019, 10:19:37 PM
a.king21
Quote from: rickfriedrich on June 28, 2019, 11:01:44 PM
The copyright is just a joke.  I did this so long ago that I was surprised to find it.
I was not referring to you Rick, just those that do not know about Benitez and his use of the earth grounding.
Surely people can put my Don Smith post together with the Benitez post and experiment with the components.
Even Don did not show the final schematic.  He just described it.
a.king21
Rick:  I've just looked back at AGs posts.  He started in April 2014 and it seems he was very optimistic then.  He then seemed to follow the ususal "gurus" and it would appear AG became thoroughly annoyed by the time wasting and failed replications - and I believe this has led him into confusion.  I think he is testing you because he is disillusioned - (like many others).
