Confirmation of OU devices and claims
Started by tinman, November 10, 2017, 10:53:19 AM
vasik041
Quote from: Void on November 14, 2017, 01:19:38 PM
Many people here are quite limited in free time. ;) I don't see why you shouldn't be able to post
a brief description about what specifically you think is unusual with your setup. :) Just a few lines
to say what you think is happening that you think is unusual or notable.
Very well. Pulsing coil on ferrite core with very short and high current pulses produce NR.
Nothing really unusual. Many people claimed it but nobody demonstrated it.
With minimal efforts you can see a real FE effect... and experiment arranged so that you don't need do precise measurements, you just see it on scope traces.
Thank you for your time :)
partzman
Quote from: vasik041 on November 14, 2017, 01:44:13 PM
I for one am interested in what you have to say here.  If you would, please attach your pdf so those of us that do have the time may gain from your experience!
Regards,
Pm
Void
Hi vasik041. Thanks for the summary. :)
I did browse quickly through your PDF, but the main potential problem I see is there
really is too much room for measurement error and outside influences such as electrical/EM background noise
skewing results at really low power levels like that. I have seen what appears to be very interesting effects at
low power levels as well in different setups, but I have found that what can appear to be OU at very low power levels
may well not hold up when scaled up to higher power levels. Other people here might be interested to look into
your setup further however.
Edit: Oh, I see 'NR' means negative resistance...
Void
Quote from: partzman on November 14, 2017, 01:54:24 PM
Regards,
Pm
Hi partzman. He already did attach his PDF to his reply in Post #101...
vasik041
Attached PDF describes shortly how I came to it.
PDF with experiment is here http://overunity.com/17491/confirmation-of-ou-devices-and-claims/msg513078/#msg513078
There is also thread on OUR http://www.overunityresearch.com/index.php?topic=3453.0
Hope it helps somebody.
