Milkovic vs. Bessler...
Started by iacob alex, November 28, 2006, 12:47:49 AM
iacob alex
...if you situate face-to face   www.veljkomilkovic.com/OscilacijeEng.html   and    www.evert.de/eft720e.htm  .Veljko Mirkovic's "Mechanical hammer with a physical pendulum"(it really works) can be a validation and a proof of Bessler's Wheel?It seems so.The one and the other ,play a lever-pendulum configurations in gravity and inertia,so to realize self-motion.That is we have two procedures?Maybe more...All the Bests!/Alex
iacob alex
...can be a name for this Milkovic's "mechanical hammer with a physical pendulum".When we confront the paradoxical,puzzling around us...we expose ourself to reality.The oil pump jack(nodding donkey,horsehead pump that "nodds" at a regular rhythm in oil fields) is intended to drill oil/energy from a downward source.Milkovic'c elementary machine, is like an upward /gravity pendular pumping system.An oil jack pump,in a short description operates so:a prime mover/engine powers a rotating crank,that moves an horizontal lever(walking beam) up and down to operate a pump.In a "mirror" short description,the gravity nodding donkey can operate so:a prime mover/gravity pendular pump powers an horizontal lever(walking "hammer"/mass) to operate a power storing system.If input/outpur >1(why we need a so great ratio/12 ?),the system becomes so interesting!You know,invention breeds invention:to do just the opposite of a oil pump jack...but if we look "vis-a-vis".In some games,the most important decision is the way you bet.All the Bests!/Alex
iacob alex
....to swing a pendulum(any mass with an eccentric CoW/center of  weight/ face to  the pivot,support) in your hand.What  do you feel?  I  feel  a  pressure,push that is  "lost"  cyclically  in my hand. In the Milkovic's  pendular hammer,this one  is transffered,not wasted.As  Goethe said,feelings go farther than thinking.All the Bests!/Alex
iacob alex
           Hi!
    A peculiarity of  Bessler's Wheel(as explained at   www.evert.de/eft730e.htm   ) and of Milkovic's  "Hammer with a pendulum" (as you find at   www.veljkomilkovic.com/OscilacijeEng.html   ),is in the same time a common method to collect from the fulcrum/pivot ,the decreasing oscillatory charge-discharge of a free swinging pendular motion.
     Usually,this stress,in a common pendulum,remains  "immerged" in the fulcrum,support  because is considered as an uninteresting physical tension or pressure.
     Maybe  Bessler,bur evidently Milkovic take advantage of it.
     As you swing a pendulum in your hand ,and all the pressure that you feel is "piled up" ,gathered  in some way ...
                    All the Bests! / Alex
iacob alex
    Hi!
So,we have "bad" news for skeptics,if you take a look at  http://www.micropixel.biz/veljkomilkovic/videos/Veljko_Milkovic_(video-8)_Universal_two-stage_oscillator_full_presentation_wmv
