Thanks to ALL for your help!!
Win Nobel Prize by doing new double slit experiment
Started by isawit, November 19, 2017, 01:33:40 AM
profitis
"The thng that doesn't exist, from a photon's point of
view is TIME."
effect is time
profitis
"Quantum indeterminacy and a probabilistic universe
based on the Copenhagen Interpretation of Quantum
Mechanics has been proven false!  It's been proven
false, John!"
Tell me something,has it ever been proven that matter or energy appear from utter nothing.if time can convert to energy then this might not be so false as you think
profitis
"Tell me something,has it ever been proven that
as you think"
Which brings us to the question,"what came first,time or energy"
isawit
the photons carry momentum?
how? what mechanism? does a photon has mass? charge? what is photon made of? virtual particle? what is it?
how electrons emit photons? fart? how electrons change energy level? what is energy level? what is energy?
why electrons do not stick to protons under attraction force?
how photons pass glass? reflect from metal?
do you understand the mechanism of light now?
isawit
Quote from: isawit on November 20, 2017, 03:52:54 AM
faraday's em induction law is description, not explanation, they don't know the mechanism of magnetism yet. they don't even know the mechanism of light.
MAGNETISM
2 parallel wires at r distance, the free electrons in the 2 wires repel each other with force f=Ke x q1q2/rr, that force is the carrier of energy/moving electric force/emf. that force act as a class 1 lever with the fulcrum at the center, the mechanical advantage is equal to 1.
if electrons move in wire 1, electrons in wire 2 will instantly have opposite direction emf. the true mechanism of electromagnetic induction. same as momentum conservation.
every magnetic atom/magton contains 2 atoms. 2 atoms of a ferromagnetic matter before magnetize, we put it as 00. if 1 electron moved from 1 atom to the other atom and stays there as -11, the 2 atoms become a magton, it carries a special property now, we call it magnetic force.
-11, -22, -33...-nn are all magton, but carry different magnetic force strength.
2 magtons attract each other in the direction -11><-11, and repel each other in the direction -11<>1-1 or 1-1<>-11.
use copper wire winding around an iron core, put a current, the electrons in the wire move in circles around the core, make atoms in the core arrange into -11-11 directions all the way. on the pole plane area, magtons are arranged as clockwise concentric circles of -11-11 directions, north pole.
reverse the current direction, the pole plane area magtons are arranged as counterclockwise concentric circles of -11-11 directions, south pole.
so, a magnet north pole stored clockwise electric force, south pole stored the counterclockwise electric force. the same poles always repel, different poles always attract.
the earth magnetic field is a mistake. there is no field but the force in the universe. sunlight moves electrons moving westward causing earth magnetic force interact with compasses.
there is only 1 force exists, coulomb force f=Ke x q1q2/rr. gravity and magnetic force are both different configurations of electric force.
without matters, there is no force. a single matter has no force. force can only exist between matters.
without a test body, where is the electric or magnetic field? where is gravity field?
the mysteries of the universe are within 2 equations.
f=Ke x e1e1/rr and f=G x m1m2/rr.
those 2 forces rule everything existing.
the mechanism of quantum entanglement is simple. the force between any 2 charged particles f=Ke x qp/rr is the carrier of energy/information/moving electric force. it is an invisible physical rod with zero mass that always connected 2 particles as 1. if 1 particle is energized, that energy instantly transferred to another. from f=ma, m=0, so energy instantly moved from 1 particle to another. we call it QE.
