Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
What would happen to the inductive kickback if we reduce the wire thickness between the end of Igor's pulse coil and the negative electrode of his power source battery and run a thicker wire between the top of the coil and the positive electrode of the reverse biased LED with it's negative leg attached to the positive electrode of the battery?
citfta
The problem is that frogs really do have wings.  We just can't see them.  Which makes just as much sense as the rest of this thread.
synchro1
Quote from: citfta on February 27, 2018, 05:58:59 PM
@Carroll,
How droll!
Quote from Jerry Bayles:
"The base of two resonant Tesla coils could be the current input from the Earth and the tops would be the high voltage open ends of a quarter wave complete transmission line coupled in quantum fashion where the coils also had a total impedance equal to the quantum Hall ohm".
synchro1
I'm nearly done with a replication of Igor's "Reed Switch Spinner 2". I will upload a video soon.
synchro1
Wiring a serial bifilar solenoid coil with a ferrite core and elastic GAP magnet piston overhead into a Bedini SSG where the charge battery is positioned should amplify the inductive kickback enough to loop the output for a self runner. I use a small capacitor to control the LC tank resonant frequency to regulate the oscillation. I believe it would help to by pass the diode to the charge battery in John's SSG circuit serial bifilar needs a Here's a video of the oscillator working off BEMF from a reed switch spinner:
https://www.youtube.com/watch?v=_hMmJlc6emw
