Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 171 Guests are viewing this topic.
synchro1
                                                            Back spike power stroke
The Axle coil needs to generate sufficient magnetic force from the primary flyback to free the core attraction to the magnet stator. The attraction to the stator can be controlled by adding or subtracting ceramic blocks along with the inclusion of a spacer. This will free the axle to attract to the opposing backing magnets with sufficient force to depress the spring pressure switch. This attraction force can be controlled by adding or subtracting magnets along with a spacer too. Balanced opposing attractions along with two attraction neutralization pulses.
The primary is charged by a 3055 transistor from a 9 volt battery, connected through the switch to the transistor base through a resistor. The high voltage flyback from this power assisted pulse, is passed to the secondary axle coil through a zener diode.
The BEMF that charges the 9 volt run battery from the secondary through a FWBR would generate as a lower voltage inductive type with input polarity Current.
This would be a genuine unity motor generator, the overall output of which would multiply from scale up.
synchro1
Luc's last in a series 20% power for equal magnet throw recycled flyback video. Luc's most definitive video in the series:
https://www.youtube.com/watch?v=7QUYkilgkzU
synchro1
"Hi Cat,
thanks for posting your suggestion What I'm thinking of making is an electric motor using this principal but this can be applied to many other things.The point that I'm trying to demonstrate here is this BEMF, Inductive Collapsing Field, Flyback Voltage or what ever you want to call it! has many more times the power to react with a magnet then the energy it takes to create it.To me, that is amazing enough!... it is real and right in front of us  Lets use it
Luc"
Luc says we're in for five times the force from the kickback alone. Increasing the magnet strength and coil mass can increase this force by direct proportion. This design turns the backspike secondary into the primary. The primary merely acts as a trigger for the flyback.
It appears that Gotoluc scaled his flyback secondary motor coil down to balance the stator forces to compensate for the additional power of the flyback. Two power stroke linear solenoids can spin Luc's wheel with a geometry that allows us to scale the flyback secondary coil up to increase output.
This kickback Mendocino oscillator has the potential to go many times over unity as a solenoid. Linking two offset force oscillators to a yoke, balances the forces. They could V-12!
