Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 171 Guests are viewing this topic.
synchro1
Here's Ludic with the same 9 volt source and identical transformer vibrating an aluminum foil ball:
https://www.youtube.com/watch?v=_E5gP7zdXgY
synchro1
                                           Increased magnet core kickback energy
Quotes from Tinman from OU Research:
"My coil is 200 turns but only 33mm neo core"
"Our coils have only 200 turns, but the inductive kickback energy exceeds that of a coil of 400 turns plus-such as that of an SSG setup".
Tinman is stating that his power coil with an axial polarized Neo magnet core is generating over twice the inductive kickback energy!
Inductive kickback is directly proportional to the negative inductance induced from the magnet core.
Tinman and Jimboot should try "Diametric Neo Tubes" inverted on the rotor for power core and attraction magnets because more Webers of flux density travels across the windings when the fields merge and elongate.
A ferrite ring wound on two sides would neutralize the diametric magnet fields at the face of the coil and require much less input. The coil on the extended magnet cylinder would turn into a piggy back output coil on the extended core. The output is generated by the magnet field stretching caused by the approaching rotor magnet in attraction. Tinman has his rotor magnets wound and connected to a voltage multiplier on the rotor, to harvest the contraction and expanding force field in the rotor magnets.
synchro1
                                                      Flash camera circuit.
We can discharge the flash camera capacitor into an EM coil, pop a magnet and recharge the AA power battery by connecting the negative electrode of the EM coil to the "split positive" pole of a AA rechargeable battery through a diode. This pulse recovery loop has tested out to be 90% efficient. That leaves the magnet torque generating potential; It would only take a tiny tickler wire from the Sono-Battery to keep the self runner AA topped off.
synchro1
                                             COP 2 magnet core pulse coil:
Compare Tinman's COP pulsing a magnet core coil and recovering flyback through a transistor, with mine through a magnet core with the SPDT switch. Identical results!
Tinman is calling his COP 2 when it should be 1 because he's merely doubling his input power by matching it with flyback recovery.
https://www.youtube.com/watch?v=x4AULG-RiuE
