Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Quote from: kolbacict on April 03, 2020, 05:00:41 AM
https://youtu.be/jeziPoJia6w
@Kolbacict,
Thanks for the new production. You really nailed the "Neutral Zone" to tap free energy good. Your video sets a new high water mark for demonstrating conclusive proof of Overunity. Congratulations!
I believe your build technically qualifies it as a "Hendershot" type generator. A DMM on the input should show a minus sign as the "Bloch Wall" oscillation generates power and sends it back to source. Really a marvelous effect!
synchro1
This video demonstrates the spontaneous oscillation inside a "Bloch Wall" following Ernshaws theorem. This Russian experimenter has apparently achieved perpetual motion with a "Neutral Zone" permanent magnet motor gate:
"Earnshaw's theorem states that a collection of point charges cannot be maintained in a stable stationary equilibrium configuration solely by the electrostatic interaction of the charges".
https://www.youtube.com/watch?v=gvV8rcOp7G4
My magnets are offset and unbalanced to stretch the "Wall" the same way this inventor does. I believe he is authentic and not a "Mylo"! He dislodges the sticky cog spot with Ernshaw's "Disequilibrium Force"!
The rotor magnets encounter "Shifty Ground" when they pass into the powerful "Neutral Zone" gate!
kolbacict
for some reason, I do not get this effect with other vibrators and coils. :-[
e.g. transformer steel plates, leaf springs ...
synchro1
Quote from: kolbacict on April 05, 2020, 10:11:58 AM
The "Russian" stresses in his videos that the strength of the gate field must be stronger then the rotor magnets.
Look at the massive amount of magnetic strength he's focusing on that one point in space where the track cogs!
The 1" Neo cube magnets I use on my electro magnet are very very powerful Neos. We are witnessing the switching effect of "Domain Shift": The "Domain Shift" may be outside the magnet material!
synchro1
                                              Authenic Overunity Motor
The Russian turned out to be a hoax, but here's something that fully works: This inventor has not contributed to our discussion forum and this is perhaps the first time most of us will have seen or been introduced to this combination of techniques here.
This "V" gate motor is over unity, because the magnet core coil neutralization pulse generates an amplified backspike that's greater then the power pulse input. The other unmeasured factor is; How much power would the "V" gate magnet array generate in the power coil when the coil is in the pickup state? Surly the combination of these two types of B&EMF's would exceed the input! That leaves the mighty power and torque of the "Permanent Magnet" rotor as free power:
https://www.youtube.com/watch?v=6VKH8bgWfnM
