The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
kEhYo77
Well, it is not the same, mine is more like Tesla's Hairpin circuit.
I am not using any power from the source, only potential difference of the electric field to seperate the charges between two inner capacitor plates... :)
peper10
Quote from: Tajerek on December 18, 2017, 03:47:45 PM
yes this would work, that is the same design I shared in my article. Some more calculations have to fall in place though for optimum results.
for instance the wire gauge used in the L2 inductor should be able to carry the current. The winding ratio also of the coupled inductor. And the rate of discharge across the spark gap to match as much as possible the tank circuit formed by C1 and L1 to guarantee the full energy is dumped from the cap to the inductor core. The choice of the diode also should not strangle the output current.
Excuse to suggest an arrangement I have seen correcting the Don Smith schematics..  That`s what I suggest to maximize the potential...  Like your schematic suggest, the spark gap and the capacitive plates need to be inverted or exchanged with each other...
Tajerek
Quote from: blueplanet on December 18, 2017, 01:22:39 AM
I suggest we read less textbook. And read more Tesla's literature. Reading too much textbook is bad for our brain and for our future generations.
In your text book, we are brainwashed to believe that increase in voltage will always come with decrease in current. This is a condition to make sure that you will always obey the laws of thermodynamics.
The truth of the matter is that you don't even need to throw away the text books, because I am using textbook formulas where overunity is staring people in the face. But when a person is indoctrinated to believe something even if the formula is in front of them they won't be able to see it.
I will list here a known proved text book formulas that any person with engineering background cannot dismiss, they bear the secret to overunity that I am talking about . It all lies in the intrinsec properties of the capacitor itself, most people even in this forum treat the cap as a 'resistive' load consuming power equal to V*I . But that is not the case
Formula 1) The 'displacement' current across a capacitor is I = C*dV/dt
Meaning : it is the voltage change overtime that creates what looks like current across the capacitor, but that is NOT current coming from the source of the varying voltage but current created across the capacitor as a result. It is just displacement current to goes to zero when cap is filled up and then the cap acts like an open circuit to DC. ie no current again from the source.
Notice that the formula defines that 'instantaneous current' in relation to the source voltage and C and Nothing more. --> current from the source is not of any value here.
Formula 2) The Charge on capacitor Q = C* V_source*[1-Exponential(-t/RC)]
This is again great secret for those who can see. Notice how the charge (ie. the energy) overtime is defined in relation only the voltage of the source , R , and C . No mention of current here because it doesn't affect the charge on the cap. Only voltage does. You don't believe it ? look again at the formula. The overunity secret is right there.
Formula 3) The energy stored in a capacitor is E = 1/2*C*V sqr
This sums it all up. The energy is directly related to the voltage across the cap and C. NO source current is present here. What does this mean? it means if you want to increase E, you just have to increase V or C. There's nothing to do with the current of the source.
Formula 4) The time taken to fully charge a cap from a voltage source is 5*R*C
If you think with low current the cap will take forever to charge and therefore impractical, then this formula tells you that the time constant is not in anyway related to the current of the source, but in direct relation to R and C and nothing more.
The rest of the invention is just conventional science to efficiently extract that energy from the cap and convert it into a useful current. I do that by the use of inductors.
Tajerek
Quote from: kEhYo77 on December 18, 2017, 03:56:36 PM
You are right I didn't pay attention you put 2 caps. But you have 2 caps in series which are nothing more that one cap wher 1/C=1/C1 + 1/C2
Tesla hairpin is slightly different but I don't think your design would give most efficient output.
Tajerek
Quote from: peper10 on December 18, 2017, 04:18:58 PM
Not really, if you put the spark gap across the Highvoltage module, you would be arching the High voltage though the spark gap. That doesn't give anything. Moreover without arching through the gap the cap doesn't charge.
What we are after is "the disruptive discharge of the condenser" as Tesla calls it. So we need to maximize the charge flowing directly to the capacitor by directly connecting the cap to the HV side , then when the cap is charged to a full it discharges disruptively through the gap. And by doing so a surge of current flows to L1.
