Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Zeitmaschine
BARBOSA-LEAL AND THE DIY WELDER
WO2013104042A1: »4. Equipamento eletromagnético, de acordo com a reivindicação 1, caracterizado pelo fato de que elemento condutor em circuito fechado em si mesmo (4) é polarizado com uma tensão.«
Translation: »4. Electromagnetic equipment, according to the claim 1, characterized by the fact that the conductor element in a closed circuit in itself (4) is polarized with a voltage.«
The ambiguous phrase »polarizado com uma tensão / polarized with a voltage« does not exclude the connection to high voltage nor AC or DC nor pulsed DC. The »conductor element« is the anode, the concentric circles symbolize the cathode connected to ground.
WO2013104042A1: »preferencialmente duas voltas se o objetivo for geração de energia elétrica, e preferencialmente quatro voltas se o objetivo for geração de energia térmica.«
Translation: »preferably two turns if the objective is electric power generation, and preferably four turns if the objective is thermal energy generation.«
So it says, we need two windings (duas voltas) for the generation of electric energy (geração de energia elétrica). Then, is there any kind of transformer that works with two windings only? Yes, just by chance, there it one: it is a DIY transformer for a spot welder wound with two turns of stout wire. Are there any reports of something strange going on sometimes when working with a spot or arc welder? Yes, just by chance, here is one: a kWh meter starts to run backwards as soon as the welder sparks and the circuit is shorted. We could easily dismiss this as »cheating the meter«, if it weren't for the Barbosa-Leal patent showing almost the circuitry of an arc welder. He should have connected an incandescent light bulb in parallel to his welder in order to see if the bulb shines brighter or dimmer while the meter runs backwards. Could be, we are pushing at an open door.
And also just by chance, a factory-made arc welder comprises a diode bridge that doubles the grid frequency. In addition, drawing sparks means generating sharp voltage pulses and generating ionization between the electrodes (here rather with low voltage than high voltage). Further we can read in the comments: »The equipment gets quite hot after a while, it is ok for experimental purposes.« Like the Barbosa-Leal patent states, it generates thermal energy.
Thus, we have here a two windings coil short circuited, a frequency doubler, ionization, sharp pulses and a connection to ground. Sounds all familiar. The result then is a power meter that runs in reverse. Just one more odd happenstance, I guess. If, for some reason, one has no stout wire at hand, maybe a thick coaxial cable could also do the job.
When an ordinary motor is connected to the grid together with a bank of capacitors, could that also cause a Ferraris electricity meter to run in reverse? If no, then that welder does not simply cheat the meter, it indeed generates its own power and pushes that power into the grid. If yes, anyone (using a meter without an in-built backstop) could connect a capacitor bank to his vacuum cleaner, etc., in order to power it for free, and even get paid for using it. Nice.
Indeed, the electricity companies are concerned about electricity meters running backwards, though not because of a malfunction, but because of their tariff policy (import-supply tariff vs feed-in tariff). On technical basis, backwards running meters are in perfect working order when a solar panel exports electricity to the grid. This has nothing to do with power factor and reactive power, as suggested by some. Of course, suggesting the generation of free electric energy out of thin air does not comply with the textbooks.
Merry Christmas, by the way. Anyone uses aether powered Christmas lights yet?
iflewmyown
Zeitmaschine,  I just got back in from trying your test on the welder. First let me explain that I have the perfect set up to do the meter test. I have a large solar panel bank connected to the power grid. When I grid connected the solar panels the power company installed a new meter as the old one contained a ratchet which prevented the dial to rotate backwards. It is overcast today so that my meter is running in conventional mode. I tested a Lincoln 235 amp DC welder. First I watched the meter with the welder switched on but not welding. Of course I was getting charged. Then I started welding at the highest setting (235 amps) and watched the meter. It still went forward and charged me the full amount. It was a good thing to try and there is much more in your writings that I will be trying this coming week.
Thanks
Garry
antimony
Reminded me of this video that i saw many years ago. I hope it helps.
https://www.youtube.com/watch?v=zNTDQvU1ftM Part 1
https://www.youtube.com/watch?v=2zjHZzyqzeY Part 2
It is in russian, but i think he is talking about an old welder schematic from the Soviet era.
antimony
Quote from: antimony on December 25, 2017, 02:29:37 PM
Ignore this one. I think i got it wrong.
Zeitmaschine
There is more wrong than this, as it looks.
iflewmyown, I think, they (which.co.uk) handle it the other way round: When a solar panel is installed, they change the old meter to a new meter with in-built backstop. The solar panel system has an integrated meter in order to measure the feed-in tariff. If the main meter would run backwards at the same time the owner of the solar panel would get paid twice for his solar generated power.
Also it is not sure if all welders are suitable to make the meter running backwards. The simplest may be the best one. I can't find any hint what welder he is using in the video.
Another find:
Guntis on January 03, 2015, 09:59 PM: »Remember my experiment (i think i have post here 5 years ago) with PC cooler and Tesla coil and when you get synchronous TT and PC fan motor magnetic field, then fan starts to speed up in enormous speed.«
Unfortunately I can't find any trace of such an experiment about 5 years ago (around 2010). Would have been interesting at least. How to connect a PC fan to high voltage Tesla coil without destroying it?
