Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Sergh
Quote from: tomd on February 21, 2018, 04:43:33 AM
In Thane's transformer the secondaries are wound on the outer core legs and the primary on the middle leg. "This method of construction and winding connection eliminates the back emf from the secondaries to the primary thereby freeing the primary of any effect from the load on the secondary." Effectively the primary only has to maintain the magnetizing current.
When the back emf occurs, then the primary winding is already disconnected from the power source and in any case has no influence on it and on the secondary.
tomd
Quote from: Sergh on February 21, 2018, 06:41:17 AM
I am going off Patrick Kelly's pdf and the mode of operation is as described there.
Belfior
to create this kinda transformer can I use 2 U-cores and just have some kinda ferrite in the middle as the thinner primary?
Can I use a small E-core transformer inside 2 U-cores as the small primary? How 'tight' must the connection be so that the flux is transferred from primary to the outer U-cores?
I can get something to the secondaries, but I think I am not saturating the core with my primary.
tomd
Quote from: Belfior on February 21, 2018, 07:25:06 AM
A good start would probably be to look for an EI core designed for a magnetic amplifier.
I'm only an amateur in this field. However if you saturate the core how are you going to get a magnetic pulse? For a transformer as opposed to a mag-amp, I would have thought the last thing you would want is to saturate the core.
With all these free energy devices the devil is in the details, and those that know the details are not disclosing them. So it's up to everyone to reinvent the wheel.
Belfior
Quote from: tomd on February 21, 2018, 06:08:26 PM
I already planned to make a video of my OU device, when I finally find it. I will hide all the important parts inside boxes and I will use all pseudo-Russian for the commentary. "Tak. idiotidiotidiotidiot. suka bliat. otsi tsorni. gavarits ruski ruki vehr ruski soldat" and then leave people steaming in their own juices.
