Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Belfior
Quote from: Zeitmaschine on April 09, 2018, 10:00:13 AM
It appears to me, as if there is a major problem with that rectified magnetic field and the circumvention of Lenz's law, although it sounded quite easy to do a few pages ago - or am I just slow of comprehension?
Would be an idea perhaps (in order to cause general amusement) to create a compilation of some red flags I've encountered in course of time regarding free energy demonstrations. Fortunately, there is also one scientifically confirmed green flag about energy from space, not very useful so far, but should be better than nothing.
how to place coils to negate Lenz
https://www.youtube.com/watch?v=w9MiEJ6KI8k
Zeitmaschine
When an electron moves through a looped wire, it generates a magnetic field. In order to make it move through the wire, a magnetic field is needed (although there are also other methods). That is why it is necessary to decouple the primary magnetic field from the secondary (electron-generated) magnetic field. The point here is, I haven't seen any setup that can do this in practice, it always works on paper only (or in hoax videos).
Basically, the initial idea of this thread was to shed light from all possible directions on this subject - unfortunately the sheer numbers of negative experimental results are all pointing to something rather sinister than enlightening.
THE RED FLAGS
Red flag #1, Kapanadze's ground current. The clamp ammeter shows around 22 amps in the green box video. That means the electrons moving through the wire (allegedly bouncing back and forth) have to generate a magnetic field, otherwise the ammeter would show nothing. But in my understanding those electrons are attracted electrostatically and thus should do work only in the load, not in the ground wire. Also those electrons seem to generate heat in that ground wire, hence the requirement of a rather large diameter of that wire.
Red flag #2, the size of Kapanadze's tin can. The thick orange wire which connects the five 1000W incandescent bulbs to the tin can on Kapanadze's work bench needs to be rather heavy in order to carry 5000W without overheating. But what about the electric component in the tin can itself the orange wire connects to? Its power rating should be corresponding to the power dissipation of the load. But then, how should it fit in that small round box? Even a device that takes energy from space and converts it into usable energy, should have a size that corresponds to the amount of energy it converts.
Red flag #3, the 9V battery. Kapanadze starts some of his devices with the power of a 9V battery. So, how can 9V DC lead to the generation of 220V AC at stable 50Hz? This would only be possible by means of an inverter, but, to the best of my knowledge, there is no 220V inverter commercially available running on a 9V battery (because it makes no sense). Then, should we assume that Kapanadze constructed his own small homemade inverter? But without such a »high-end electronics« inverter there is not even the slightest theory, how a simple oscillating electric circuit could convert 9V DC to precisely 220V AC at 50Hz.
Red flag #4, could there be a hidden wire? During the demonstrations no one of the observers in the videos makes any move to look if there is a hot wire hidden somewhere connecting the device to the grid. Under the work bench in the 2004 video we can clearly see a crossbar directly below the tin can, but no one seems to care about that ideal hiding place for a hot wire. From the psychologically point of view, the first thing an observer of such a device would do, is to look for hidden wires or batteries. But in this case they seem all to trust Kapanadze blindly.
Red flag #5, the Kapanadze motor. A round steel (or aluminum) disc and a round brass disc connected by means of a coiled wire, all mounted on a shaft, start to rotate as if by magic. So far - and that means since at least a decade - there is not even a rudimentary physical theory how and why this could ever work (purportedly by gravitational time dilation), neither is there a shred of a theory how Kapanadze could ever have discovered this effect in the first place. This stuff is completely outside the box.
Red flag #6, the antenna of Tesla's electric car and of the Moray device. Those antennas were connected to what? To high voltage? Then touching such an antenna would have led to electrocution and also to malfunction of the device? And what about moisture? Was Tesla's electric car not suitable for driving in rainy weather? But if these antennas were not connected to high voltage, then how could they ever do anything useful regarding the generation (or collection) of energy from air or space?
Red flag #7, Stepanov's 8,2A negative DC (virtual) ground current. It is hard to see how a 50Hz AC current can flow without a closed electric circuit, but maybe it is in theory possible somehow by letting the electrons bouncing back and forth in the ground wire. But DC without a closed circuit? Absolutely no idea.
Red flag #8, the Barbosa-Leal closed loop heat generation. Why should it be necessary to waste a lot of energy in order to get free energy? Actually this makes no sense. A thin ground wire, capturing the electrons, connects to a ten times thicker looped wire, and the claim then is, that the thin wire stays cool, but the thick looped wire must get hot in order to power some incandescent bulbs at the same time. Something has to be wrong here.
Red flag #9, the patents. Why is there not one single patent filed by Kapanadze, Stepanov, Barbosa-Leal or others that shows a comprehensible schematic of one of their devices? A patent would surely protect their intellectual property, so there is no reason in filing nonsense patents which not the brightest minds can grasp - except the reason would be, that they have nothing at all that works in a way like demonstrated in their videos.
Red flag #10, DC output. The Steven Mark TPU as well as the Testatika provide an output of clean and smooth DC. As we know, the easiest way to get clean DC would be by means of some batteries, although as we also know, batteries have a very limited lifespan. And just as a mere coincidence, precisely both of those devices were never showed connected to loads in the range of some kilowatts.
And I'm sure, there are even more red flags, e.g.: Why in decades was not one of the so-called "free energy inventors« able to bring his invention to market? Not even as a toy, e.g. like a spinning top for children driven by permanent magnets, that never stops spinning, or something like that? Which lead to more red flags: Why is no one able to replicate a simple device like the Perendev magnet motor presented in a video in plain view? What happened to the Lüling magnet motor presented in the UFA-Wochenschau more than 50 years ago? Again, after filing a patent, there would be no need to hide the principle of work - given there is a principle of work at all. The same story regarding the Yildiz magnet motor. Probably a scam? In whose interest?
THE IMPOSSIBLE TRUTH
Sherlock Holmes: »When you have eliminated the impossible, whatever remains, however improbable, must be the truth.«
Therefore, this all looks more and more as if the secret of free energy (Kapanadze, Stepanov, Barbosa-Leal and so forth) in reality is rather the secret of a giant hoax, ongoing since the 1930's. I still would appreciate it very much, if someone could prove me a liar. In lots of setups I can generate strange noises and funny sparks, I can also generate some heat, but only because the inverter is in state of overload and draws plenty of amps from the battery, not because there is any energy coming from ground or from space. A device, so simple you'll laugh, but no one can find out how it works or can find even a clue in decades, not even by chance. This is plainly not possible. End of the story.
So, what does this all mean? It means, there has to be an authority - a higher power, so to speak - which orchestrates all those undercover operations (hoaxes) over the years. But the question still is why? Do they belief it is possible somehow without knowing how, and they want to make people look deeper into that subject, so they get a lot of research effort for free? Or do they know for sure how it works and they want to distract people away in the wrong direction? Or is there more than one authority involved in this and they fighting each other over that subject?
TESLA QUOTATIONS
Nikola Tesla: »Ere many generations pass, our machinery will be driven by a power obtainable at any point of the universe. Throughout space there is energy.«
Nikola Tesla: »It is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature.«
Nikola Tesla: »I have harnessed the cosmic rays and caused them to operate a motive device. More than twenty-five years ago I began my efforts to harness the cosmic rays and I can now state that I have succeeded.«
Nikola Tesla: »This new power for the driving of the world's machinery will be derived from the energy which operates the universe, the cosmic energy, whose central source for the earth is the sun and which is everywhere present in unlimited quantities.«
If those quotes are real and not also hoax (who knows for sure?) then there is still hope; but stay away from all free energy videos and schematics; at best those videos and schematics show how it does NOT work.
CHASING A PHANTOM
A Nexus article from 2001 about Kenneth and James Corum's reconstruction of two simultaneously operating Tesla coils producing fireballs. Maybe something out of the ordinary is going on here, but unfortunately the Corum account is the only account (more like an anecdote) on the entire internet about that dual Tesla coil setup; no videos, no photographs and always one and the same plain sketch. So, are those fireballs for real or is this just another hoax? Perhaps one can find an independent replication of this setup.
There are few possibilities to get a surplus of energy (which has to come from somewhere) from an electric circuit (if at all). If we don't even know the source of the energy, then how should we ever be able to use it? The energy could come from
a) the negative charge of the electron through ground or ionization or both (maybe);
b) the magnetic field created by a coil (might be);
c) the electric field created by a capacitor (could be);
d) the Casimir effect (possibly);
e) the nuclear magnetic resonance, NMR (perhaps);
f) the combination of some of the above (conceivably).
Here my best guess at this point would be to create a combination of a classic Tesla coil and an ordinary 50Hz transformer. Should a Tesla coil ever be able to collect energy from ground and/or space, then this might boost the current in the 50Hz transformer for free. If anyone has an idea how to do this practically, please keep me informed. However, up to now, not a single credible report surfaced that an ordinary Tesla coil has ever produced any surplus energy for free, thus the chances for this are rather faint.
Anyway, there is one setup that has been proven to be capable of collecting energy from the vacuum, it's named the Casimir device (the only scientifically confirmed free energy device). Hence the vacuum contains indeed some energy, but could this be the energy which is - according to Tesla - everywhere present in unlimited quantities and obtainable at any point of the universe? The discrepancy here is that Tesla talks about the cosmic energy, whose central source for the earth is the sun. Then the sun is the source of the vacuum energy? Sounds somewhat strange, so I do not even fully trust those Tesla quotes. Also of interest, Tesla died in 1943, whereas Casimir predicted this effect named after him in 1948. Therefore, in theory, Tesla should not have known anything about the Casimir effect. But maybe he did know something about it, albeit (and of course) not calling it the Casimir effect (actually not calling it anything).
The Casimir setup consists of two parallel metallic (conductive) plates close to each other only nanometers apart. A force coming from space - the quantum vacuum fluctuations of the electromagnetic field - pushes those metallic plates together due to the difference in wave length of the electromagnetic field between the plates and outside the plates. Then what happens to this force if those plates are immovable like the two plates of a capacitor? Will this force then - under certain conditions - reveal itself by generating an electric field - or disturbing an already existing one - and thus generate a voltage between these two plates? What could happen if a Tesla secondary coil is wound bifilar, so it can work as a capacitor and as a coil at once? Or the secondary Tesla coil represent one plate (of the Casimir setup) and a shielding surrounding that coil the second one, only nanometers apart?
Again, no idea. But it could be a start to get something real.
forest
Zeitmaschine
Do not forget about Hubbard  ;)
Look how he named it. The source of energy is known for more then 100 years. The dark ages we live in, the dark ages.
Zeitmaschine
Another anecdote; nothing concrete, no evidence for nothing. The device, as usual, disappeared mysteriously, no replication since a century, no hint how Hubbard could have come across this in the first place. He must have been a genius.
And isn't it interesting that overunity is always claimed by single (maybe sometimes two) ordinary persons? Overunity is never claimed by scientific facilities like universities or by large established companies. We should think about that. It is always THE ONE that »has it«.
