Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
x_name41
antimony
I am glad that you have put all this together, and it is indeed very interesting.
RomeroUk and a bunch of others have also tried coil shorting in motors with good results it seems, so it wouldnt be a far stretch to think it would have effects in other devices too.
I have to read it again, but it was very interesting indeed.
Thanks for compiling it. :)
Zeitmaschine
»Captor de Eletrons da Terra«, principle of work, according to all available information: An anode wound on an iron core forms a closed circuit, preferably made of bare wire. That anode attracts electrons by ionization due to high voltage from air or ground. Then these attracted electrons are forced to circulate in that closed anode circuit by an initial magnetic field, generated by a primary coil, thereby generating a second magnetic field, stronger than the initial magnetic field.
There is no other interpretation, as I see this. The problem here is the exact specifications of the coils. How many windings? Thick or thin wire? Spacing of the coils? Timing of the phase-locked high voltage? And so on.
The Barbosa-Leal patent says two turns for the anode to generate electricity, that means to generate a strong magnetic field. If the aim is to just heat up the anode coil, then it should have four turns. Thus, for the time being, it sounds simpler to pay attention to a heated anode coil in order to see if something unusual happens at all, instead of connecting incandescent bulbs and measuring the current going through.
Further, I'm still puzzled what in that context the meaning could be of »polarized« vs »unpolarized« and »continuous electrical current - DC« vs »alternating electrical current - AC«.  DC generates a permanent magnetic field and so does a permanent magnet. Hence, if a permanent magnet is wrapped with a four winding anode coil and that coil is pulsed with high voltage, so the surrounding air becomes ionized, then will that coil heat up and generate thermal energy? Strange, never heard of such a thing. But who knows...
forest
You are so right...the answer to world energy crisis is always here - it's magnetic field.
The best invention is again lost - Barbosa &Leal copied Hubbard device.
Imagine what can you have HV or pulsed DC from 230V thought the diode bridge.Or both.And that's all!
It's a matter of coils to get what we need - answer me what we need to generate large output from induction ?
forest
Humans are the utmost stupid creatures. They destroy environment so fishes are dying ,but when some fish is almost extincted its value is rised and people rather to protect the species they are eager to catch them all due to high price in no-valuable currency called money :-( If they do it for mother nature how we could expect them to give all poor people free energy from magnetic field.
