Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
forest
Void
Hi Forest. Melnichenko's video is interesting, but unfortunately he didn't show
measuring the power being consumed in the two bulbs, so there is no way
to know if the power consumed by the two bulbs is really greater than
the input power. Since the bulbs are being powered by the flyback spikes,
and it is a high frequency such as 2 kHz or whatever, it would not be so easy at all
to measure the power consumption in the two bulbs accurately. Since Melnichenko
did not show how he measured the power consumption in the two bulbs, you just have
to take his word for it that the total power consumption of the bulbs is greater than
the input power. It is still an interesting setup though.
All the best...
sm0ky2
if you look in the direction the lady is taking pictures
You see a clip-on a/c meter on the mains
and the second bulb goes through an analog ammeter
It doesn't show the readings in the you-tube translation
We should seek the full version of his documentary
If we want that visual. (not that it should matter much)
as Void pointed out, the accuracy is almost non-existent
It's difficult to calculate these interactions.
it is an asymmetric magnetic field.
The Maxwell-Faraday equation can deal with this,
but it is not as straight forward as a coil and an inductor,
or a coil and magnet.
the field density is different on one side than the other,
and we have to deal with the second magnetic field.
(and the tension caused by this)
and what this does to the electric induction.
instantaneous current through one end of the coil,
is not the same as through the other end,
each loop of the wire must be calculated with the
appropriate field dynamics, at that location along the wire.
sm0ky2
Belfior
This is the reason any respectable OU setup needs to be self running. There can be no "switch charging battery with the load battery every 15 minutes" or any other kinda bullshit that can be interpreted what ever way people want.
If the device is self running it doesn't matter if there is 0 meters on it or if the device runs on 2MHz. Self running with a light bulb on top of the pile. That's it.
