inertial propulsion with gyroscope
Started by woopy, January 16, 2018, 04:39:01 PM
sm0ky2
sm0ky2
Consider the M in the drawing to be the part
of your device where the track dips down.
And notice the direction of the force indicated
by the black arrow v
sm0ky2
You will also notice the time delay of the transfer of inertia
and how this detracts from the opposite impulse when the
track goes back up.
If you narrow that distance, you should see the momentum
carry through even stronger.
Strengthening the forward impulse,
and weakening further the backwards impulse.
sm0ky2
increasing the height of up/down motion
will also have a beneficial effect, to a maximum
then will become less beneficial the more you angle it.
Ideally, you want the lowest point to place the axis perpendicular
to the surface it sits on.
so the gimble-arm rotates horizontally and the gyro is vertical.
When it rises up, it tilts the axis
then drops back to horizontal
that way 100% of the impulse is horizontal.
Tuning both of these parameters
can help you improve your device
sm0ky2
If it drops at an angle, it will still work
https://youtu.be/4foY5r2TMOo
just not as well
