170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
justawatt
In the video he is showing the electronics and relay circuit is to produce a rotating magnetic field.
If so we can replication this setup with a 3 phase induction motor with VFD to control rotating magnetic field.
And just remove the rotor and replace with his 2 pair 20AWG coil wire on a solid block of metal with outlet to take power.
Then this is the setup if it works ,no need for complicated circuits.
Reference of rotating magnetic field in 3 phase motor
ariovaldo
Quote from: justawatt on February 21, 2018, 10:54:17 AM
I agree that we can simulate that.  I was just think about that last night. will try!
Just two points to take in consideration:
1) If we connect the VFD straight to the motor stator without the rotor, we can fry the motor, unless we set the vfd in v/f and start with low frequency.
2) It looks like he is recovering some "juice" using a second winding in the same stator slot. So in this case we need pulsed dc.
justawatt
Quote from: ariovaldo on February 21, 2018, 11:02:17 AM
yes i knw , thats why he has used 24volt dc .
if we modify the vfd to work in safe zone then it will be possible.
Any one here with induction motor and vfd drive knowledge  ,please contribute.
ariovaldo
Quote from: justawatt on February 21, 2018, 11:49:26 AM
Yeap. That is my field.
Next week I will test that.
Acca
Ari how are you going to eliminate the back EMF ?  This is where the relays switch to capture the downward collapse of the magnetic opposing the field .
Acca..
