170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
r2fpl
gyvulys666
hi
attached edited konehead picture . shouldnt   sequence be like in picture i attached in order to make full 360 degrees rotation?
cause some magic numbers seems missing :)
gotoluc
Salut Pierre, peux-tu regarder un vidéo en français que j'ai faite pour toi et s.v.p. confirmer si le bobinage de mon stator est correct.
Il y a encore beaucoup de confusion au forum sur le sujet et ton aide pour confirmer cela dès que possible serait grandement appréciée.
Lien vers la vidéo: https://youtu.be/kjWRzd3qKIM
Merci pour ton temps
Luc
English translation
Hi Pierre, can you please look at the French video I made for you and confirm if my stator coil winding is correct.
There is still much confusion at the forum on the subject and your help to confirm this as soon as posible would be greatly appreciated.
Link to video: https://youtu.be/kjWRzd3qKIM
Thanks for your time
Luc
konehead
Hi Gyula
The red wire you drew within stators that connect through adjacent poles is how it must be and that seems correct. The pole numbers are also correct, the rest of it forget about it eh!
The last drawing I put up with the question marks was meant to show that this method does not work out right,  (and has not  the adjacent poles in it like yours does)
If winding (weaving) the one "good-wire" as shown in your drawing (the red inner wire not the rest of the mess outside the frames)
This red wire would go DOWN through slot 6 then come back UP through slot 7 (adjacent slot) and the jump again over to the slot 12 go DOWN through that, then UP through 13 and so on....(weaving) Finally the beginning of wire connects to the end of red wire too, so a completed circle.....Pierre mentioned intertwined or interweaving wires....so this describes how it will be when everything is connected up and there will be fiver circuiar "strings" within the "rope" of circular wires...
All ends of the coils must connect together, as Pierre clearly showed in this drawing of his switching circuit so seems there are 5 connected-ends circles to the stator wiring....note there should be in finished product, 2 wires per slot.....
gotoluc
Quote from: konehead on March 14, 2018, 10:57:17 AM
Hi Gyula
Hey Doug, is your message for Gyula or for gyvulys666 who just posted above your post?
Luc
