user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
Grumpy
Should that screen be grounded?
Keep all hands and other body parts out of the center of the ring or around the ring - especially at the lower pulse widths.
QuoteFROM TESLA:
0.1 millisecond duration:
  • produced pain and mechanical pressures
  • objects visibly vibrated and even moved as the force field drove them along
  • Thin wires, exposed to sudden bursts of the radiant field, exploded into vapor.
100 microseconds or less:
  • Pain and physical movements ceased
1.0 microsecond duration:
  • strong physiological heat was sensed.
Impulses of 100 microsecond duration (or shorter) passed through all matter (except the collector coil), a fitting form of electrical energy to broadcast throughout the stone, steel, and glass of a power-needy city.
QuoteFrom the EE world - Clock  signals with clock  frequencies much  less than 1MHz, and  rise and fall times in the nano seconds range could have Fourier spectrum extending all the way in  the hundreds of Megahertz range or even higher.
RF meter anyone - (pretty simple one)?
http://www.qsl.net/n9zia/wireless/appendixF.html#8
http://geocities.com/ajpotts19/wavemeter.html
http://www.qsl.net/n9zia/wireless/LED-rf-pics.html
EDIT: fixed list bullets
        -Frank Edwards
giantkiller
Quote from: aether22 on January 05, 2007, 06:57:04 PM
Quote from: Spherenot on January 05, 2007, 06:04:34 PM
Quote from: aether22 on January 05, 2007, 04:12:58 PM
I don't want to make 1200 of the turns in the wrong direction.
Please see my attached picture...
aether22, in your image: you might want to use hidden lines for the wires coiling behind and out of view of the toroid.  I can see it winding two ways without hidden lines.  I got your back.
I had made the wires at the back purple, but I agree it wasn't clear enough.
I have attached another version as per your suggestion.
Giantkiller, please clarify this, otherwise I could waste a lot of time and copper wire. (mainly time)
the direction of the magnetic field is likely very important!
Also it might be that the difference between Otto's results (lots of energy out) and GK's results (impressive aetheric effects, not so much energy) is exactlly this issue. (it's either that or the iron most likely)
This clear: the feedback and the controls are in the same direction. From the position in in your face, you go over the top and wind to the left. In example: looking down then you will follow a clockwise direction. Kapeesh?
Draw that. Then connect by Ottos diag. In his diags wire by to one ring picture then by the 3 ring picture.
--giantkiller. Paint by numbers. Ok, now pick up the blue crayon. Just kidding.
giantkiller
One day...
Someday...
Never,
No more!
This time is now!
--giantkiller. Let's rock the planet!
IronHead
I will say this again more  clearly.
Tuning Fork , strap it to the device DO NOT TOUCH THE RING !
And yes Grumpy the cage must be grounded.
aether22
Quote from: giantkiller on January 05, 2007, 07:05:30 PM
That description just isn't as clear to me as it is to you.
Look at the new picture I've attached, the only difference is that the segments have been numbered.
From what you say I gather the fields in your design are bucking, so 2 of the segments need to be wound in the opposite direction, if this is so please tell me if it's 1 and 4, or 2 and 3 which need the winding direction reversed.
Thank You (I really want to get building started today, but without this info copying your design propperly will be maddening)
