user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 85 Guests are viewing this topic.
giantkiller
Warning, warning Will Robinson!!!
Do not allow any touching of the TPU. If it is not shielded then do so!
you'll cooking the dog and painting the kids with sunblock.
Please. Shielding and no touch!
Been there done that. Boy, what was I thinking of. And I posted einstein's remark to Oppenheimer when asked 'Hey Al, is 50 feet far enough away from the nuclear balst zone?". Al replies 'Uh, how about 50 miles...' And so goes history.
Please heed!
Spherenot
Quote from: Gearhead on January 05, 2007, 08:39:34 PM
...tapping into the..., or the nearest power from the grid.
Nobody here wants anything to do with that.
Hey, GK, once your device is portable you need to take it to the woods, far away from the grid, and see if it still exhibits the same effects, no?
Welcome aboard, Gearhead!  Got a scope?  ;D
aether22
GiantKiller, I have all the coils now wound in the same direction (which due to the connection system makes the fields opposing) in what is seen from above in a clockwise progression around the torus starting from the negative terminal. (though it strikes me that the only difference between a cw progression vs a counter clockwise progression is which way is up, turn it upside down and it's a ccw progession)
As per your instructions over the top, through the hole and around the back, this breathes a bucking B-field.
So this diagram is correct right? (it must be)
BTW is you have an iron ring collector insulated from the rest, and charge it positivly there is a chance of lift-off (though you may need more tpu's with opposite aether flows), or if you get a few and interlock them or otherwise have several focusing on a point you will also get levitation.
Finally if you manage to overload steel wire (and maybe iron wire) in the right way it will turn transparent then invisible. (got lots and lots of stories I have correlated about that)
It seems steel just isn't able to take too much excitement, it stops responding to light in any way.
hartiberlin
Quote from: aether22 on January 05, 2007, 04:12:58 PM
GK, the thing I really need an answer on before I can begin building is how to wind the control coils.
This can be answered either by you saying if they are bucking or not, or better yet you drawing a diagram. (where about 2 turns represent 200, with the core transparent)
I don't want to make 1200 of the turns in the wrong direction.
Please see my attached picture and carefully study it to ensure it is correct. (all in all there are 8 different likely and many more possible winding direction combinations)
Hi,
you make all the windings into the same directions on all the cores.
Also the feedback coil, which Otto says, he also did devide and put as 4 "control coils" !
Then you can play with the configuration outside of the TPU,
if you take the coil endings out of the TPU and connect them
just outside.
This way, you can try several combinations.
@GiantKiller,
please don?t post these Anime pics with your postings..
Okay, they look nice, but it is offtopic and it just
only fills up the attachment folder.
Better post a few pics of your TPU.
Do you have a camera, so you can post pictures ?
What input power do you feed into your TPU ?
At ardoun 12 Volts and 8.5 Amperes you are already in
the 100 Watts input range, if you use this much and
this surely will heat your coils...
So how much power do you get out then ?
Many thanks.
Regards, Stefan.(admin)
giantkiller
Quote from: Spherenot on January 05, 2007, 08:46:41 PM
It'll probably still squeal like a pig, but I won't be touching it. I hear banjos.
And remember: Only TPUs can't prevent forest fires.
