user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
Spherenot
Quote from: starcruiser on January 06, 2007, 11:40:46 AM
I have expereinced a setback on finishing my latest TPU, It appears that the way i made the collector will not allow the collector wire to move enough when I try to bend it into a circle.
I now have to fix this so I will need to rewind the control coils, ugh! Well I will be very busy today, I had to run out to the store today to get a few more supplies. Back to work! I will get this up and running this weekend!
Oh, snap!  >:(
I was thinking this might happen when I saw your photos.  ::)
Try lightly greasing up a long rod, ooh my, (about 5~10mm diameter,) and wrapping it with your core coils.  When you are done wrapping, slide out your rod and call a cab.   :D
This should give you enough room to bend.
Also, you realize that the core wires on the outer edge need to be longer than the core wires on the inner edge.  Unless they all need to be the same length; then deal with the V-shape formed by the cut wire ends.
Hope this helps.  Sorry I did not mention it when I thought about it.  I assumed that you had this detail covered.  I'm just a newbie.  :-[
IronHead
Not necessarily  microwaves. Since you will all be playing with many different frequency's and combinations of those frequency's you should build a
grounded Faraday cage.
Some of you will hit on frequency's that will project a radar image and beyond .This will bring an investigation on.
You might also hit on frequency's that will disrupt the cell structure that make up the human brain and body.
I urge all of you to treat this experiment with respect and take any safety measure necessary.
Spherenot
Perhaps now would be a good time to look into safe, or even beneficial, frequency ranges.  Grumpy posted something on this earlier in another topic:
Quote from: Grumpy on December 06, 2006, 07:14:31 PM
* 5 Hz: Alleged sphincter resonance (mechanical)(not good)
* 7 Hz: Mass aggregate frequency (can deaggregate matter), alleged to
resonate and rupture organs at excessive intensity
* 7.5 Hz: (?) Earth magnetic field frequency, useful theta (brain)
waves frequency
* 7.83 Hz: Earth resonance frequency
* 13 Hz: Alleged sphincter resonance (mechanical)(not good)
* 46.98 Hz (use with 62.64 and 70.47) Useful for weird effects
* 62.64 Hz (use with 46.98 and 70.47) Useful for weird effects
* 70.47 Hz (use with 46.98 and 62.64) Useful for weird effects
* 305 Hz: Rife frequency to kill Lyme disease
* 312 Hz: Rife frequency to kill Lyme disease
* 345 Hz: Rife frequency to kill Lyme disease
* 432 Hz: Rife frequency to kill Lyme disease
* 620 Hz: Keely Frequency (use with 630 and 12000)
* 630 Hz: Keely Frequency (use with 620 and 12000)
* 864 Hz: Main Rife frequency to kill Lyme disease
* 2000 Hz: Commonly used Rife frequency
* 2000 Hz (plus a small amount): Alleged to cure a cancer
* 2025 Hz: Proton precession/water resonance
* 3000 Hz: (approximate) Mentioned as a Rife frequency
* 5000 Hz: Commonly used Rife frequency
* 7270 Hz: Commonly used Rife frequency
* 7870 Hz: Commonly used Rife frequency
* 8000 Hz: Commonly used Rife frequency
* 10000 Hz: Commonly used Rife frequency
* 12000 Hz: Keely Frequency (use with 620 and 630)
* 38000-40000 Hz: Magic window
* 42800 Hz: Aetheric dissociation/water resonance (water -> aetheric
force)
* 150-160 kHz: Magic window
* 180 KHz: Ferromagnetism
* 1.1-1.3 MHz: Magic window
* 388 MHz: Alleged to cause damage/disruption of humans
* 488 MHz: Same as 388 MHz, but I think it was a mistake, and 388 was
meant
* 1.057 GHz: Magic window
* 2.450 GHz: Standard microwave oven frequency, but no resonance
* Somewhere in the Infrared: Magic window
* The life energy frequency (in the near ultraviolet): Magic window
Others:
172,500 Hz
500 KHz
@5.5 GHz
Rife?... http://www.medicaltruth.com/rife/elecpath.htm
giantkiller
the green garden wire has a coat. I believe the wire it is iron. Chinese co. cant find out. If it is steel then I am glad because the results would have been greater.
I am going to measurement and then I am going to Mosfets next. I was told to shield first. In order for that I need to consolidate the wiring for smaller packaging. It is necessary for portability.
4 segmented feedback thing was an instruction I was following from Otto. Doesn't make a diff. just connect them in series.
The mosfet gives faster on time. Higher freq is not the goal here. It just diff results. But the low freqs are where is at. Just fast on time. I posted this rocket science before. You are bashing the electrons faster than they are willing to change. The polarization stress is what we want not the alignment.
My test with placing the ndbmags and grabing the ring, ooh new term, I like it!,  showed me a tremendous amout of energy in the coil. The magnets shook at a rate that did not match up to what I was pulsing in at it was strong!!!!!!!!!!!!!!!!!. The speed at which the heat shot up when the kicks sync up is another thing that has not been experienced elsewhere. You can feel it rise immediately. And that is a very dangerous field generated. And here is the kicker: the bipolars were'nt hot, nor any of the surrounding circuitry or cabling. No way, you say? Well Yahweh cool. I am the grabbing the ring and tweaking the freqs. So if anybody hasn't done this then be still, wind it up and give it a try. You'll see.
@starcruiser, my suggestion is copy what I did. It produces results that immediately showed up. Nothing mysterious. You saw my list post of all the effects that everybody at one time were trying to think about without trying them. The same brain work has arose again. Remember, that list of results were scattered before and this TPU ring achieved them all. I like your posts and you should easly be #2 ringer.
@All,
I posted my results. I posted who I got the pieces and parts from. I posted in plain english my configuration. And the real results were?
The traffic to this sight shot through the roof. It was heard around the world for a day and half. The majority of the time you couldn't get in. Now how much do think that is worth? The big web boys can only dream about that  kind of barrage! New members showed up ready to get on board. I say 'Welcome to you '. Previous members have seen the possibility and are winding. It's all pretty plain. Like Marco and CTGlabs, we caused  shitstorms of unmeasurable quality.
@Stefan,
I got 2 more storm postings coming. You want them? You think your ads can handle it?
If not I can go back to the other 2 secure sights.
I posted the way did not only show TPU specs but to keep a grasp on reality. I became 'Enemy of state' in one posting. I wanted to document the rise to godmode and the emotionally depriving decent back to humility. I still have a tremendous headache. I've been here before at other times. When I felt the TPU heat up that fast the first time I shouted victory to sky so loud I almost blew my lungs through my chest. My next place is enjoyment on getting others here and then watching them fill their shorts. I need some buddies here. We all been drug through the mud with small results so far. So ya'll get on board.
yeh, yeh, yeh measurements next, but safety first.
I achieved another life long dream of incredible magnitude for such a time as this. Can you tell I am resting?
And this place for any of us is where the true support is needed. I am still but a man in god clothing. LOL.
--giantkiller.
