user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
Jdo300
Hi GK,
Quickie question for you. How did you connect your transistors to your 555 IC's? I just made a trip to the electronics store and a grabbed a bunch of supplies to build the control circuit, including 4 IRF840's that Otto used for his tests. Are there any diagrams I could grab quickly for the pulse circuit?
God Bless,
Jason O
AhuraMazda
Well, "lamp wire" could be anything. There are lamp wires made of Nickel plated strands. Of course Nickel is ferro-magnetic.
@GK,
Yes you should start a new thread.
AM
giantkiller
Quote from: Jdo300 on January 06, 2007, 07:38:59 PM
Hi GK,
God Bless,
Jason O
555 output to 100 ohms to the tip41b base, emitter to ground, then the collector to one of the coil freq connections.  Otto put 12ohms but I use 2 parallel 10ohm-10 watt for 5 ohms on the collectors.
Simple?
--giantkiller. Sorry about latency.
AhuraMazda
@GK,
In one of his German posts Otto removed the (collector) resistors all together. Can a Geman speaker/Otto please verify.
AM
Jdo300
Quote555 output to 100 ohms to the tip41b base, emitter to ground, then the collector to one of the coil freq connections.  Otto put 12ohms but I use 2 parallel 10ohm-10 watt for 5 ohms on the collectors.
Simple?
No Problem. Thanks for the clarification. So then I'm assuing that the + marked on Otto's diagram is where the feedback coil connects to the positive side of the DC supply?
God Bless,
Jason O
