user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
allcanadian
I agree completely
Most times I don't care if it works or even if it is faked, the point is to open possibilities-perceptions, to make one think.
What if the SM device is a compete fake, but I work on it and happen to stumble onto something, come to a new understanding-make it work- What then?
Pointless criticizm has never helped anyone, never has never will.
MeggerMan
Hi Turbo,
Hope you are still following this tread too.
Sorry if I implied that you were faking the experiment, it was just a small prompt for you to say "nope you're completely wrong, this is how its done...".
I think I can say that every single person here that wants your experiment to be successful and lead to bigger and better results.
I guess the best we can do now is second guess the whole experiment and see what results can be achieved trying different core materials, various pulse frequencies.
The circuit looks very simple, 4 wires for the input could drive a 4 phase, 3 phase or 2 phase pulse.
3 phase would match the 3 MOSFETS and therefore you would have a single common ground wire with 3 +ve pulse wires for the 3 windings.
Rob
Grumpy
let's slice and dice the picture - nothin better to do:
looks like there are 3 coil wraps - zoom in on the wire-tie area - but could be only two if is is the same wire:
2 sets of parallel wires and the single red wire laid over the output coil wires
core looks insulated with clear tape and unconnected - probably bare copper wire or strip - looks like about 5 or 6 layers.
circuits - (you can speculate until doomsday) - he said he had an oscillator - so be it!
taking a guess that he is pulsing with the mosfets (or whatever they are) - they could be transistors used as diodes for all we know...could be driving them with the oscillator
Just not enough there to even shoot from the hip.
What need is the operating principles of the device - several circuits will achieve the same end.
This was pointed out before in regard to a stement by TAO:
QuoteTAO - Lets say Steven put one big stout cable around or in the rings,and all around these he had many many windings. Now, if Steven put into that stout cable a current and before the current could get to the end of the wire, he stopped it's flow abruptly, then perpendicular radiations (the KICKS), the same Tesla observed, would appear and spread from this stout cable, this would cause Tesla'a copper charging effect, which would hit all the other wires in Steven's coils. Now, if Steven wired the coils right and stopped the discharge of the current through the coils he would be able to extract a lot of extra energy from the tap points on the coils. This is basically how Tesla's magnifying transmitter works.
Capacitors discharged ABRUPTLY into a wire, then the current flow is stopped ABRUPTLY before the current makes it to the end of the wire, and this KICK comes out of the wires perpendicularly. This KICK would then charge copper with electrons(hot electricity) or their opposites(cold electricity). It just depends on how you setup the device.
So, I would say that Steven's KICKS have a direct relationship to Tesla's Magnifying Transmitter, its REAL operation.
...this guy definitely has the secret. I do not know if he will be able to duplicate power generation, but he does have the secret.
Do you think he knows it?
The only part he doesn't have any idea about is that by starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation.
EDIT:
other observations of the photos:
- the core may not be connected to anything and completely insulated
- I speculate that the oscillator signal provides a "sense of direction" to the charge in the output coil, making it useful
- MOSFETs (asuming they are) may be driven alternately into different legs of the paired coil - could even be flipping pulses - who knows
I'm just grasping at shadows...
        -Frank Edwards
supersam
marcoturbo,
;)just a little note to say it has been glad to see you, posting here!!! thanks for the hard work.  i personally don't think i will ever get it figured out, without some serious help, but that is why we all come to this site.  we all need a little help now and again.
there are still alot of people working on this thing here. a little insight could go a long way.  what do you say?
lol
sam
FreeEnergy
Quote from: Dingus Mungus on December 01, 2006, 07:19:48 AM
Quote from: kingrs on December 01, 2006, 07:02:12 AM
So Turbo and X, prove me wrong, show us it again with meters and a clear bulb.
I would agree.
they don't call it Open Source for nothing. :D
