user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
starcruiser
Dave,
We have some info, would like to see if we can find more. Take a look at the TPU in the manner that layer one is the collector, layer two is the primary and layer three maybe the secondary.
Another variation would be that we have 2 collectors (top and bottom) and the primary is the center coil. The secondary would potentially be the feedback coil. This could be checked by just opening a TPU and flipping the middle coil over thus reversing the windings, the loop inside would be the copper tube. This design of course requires a single collector loop (copper), this can be a copper water pipe 1/2" or stranded copper wire (an auto audio power cable of say a 0 AWG).
Maybe Marco's new fabrication idea might help us out here. Just some thoughts, we should definitely look at possibily replicating this but of course start a new thread so as to not confuse things.
Regards,
Carl
Grumpy
Marcovich coil collects from ambiant environment.  Why collect, when you can generate and collect?
If interest, see first attachment:
For those who refuse to give up on the SM device, or a Radiant Energy Device in general:
I suggest again that everyone consider what radiant energy is - ask Turbo a few questions - not that he will respond since you guys accused him of faking his experiment, exposed his identity, etc. - or re-read his last few posts starting with the shockwave comments.  Tesla patented four different ways to capture the radiant energy - tube version looks pretty bitchin' - not too hard to make your own tubes, but I suggest the wire approach first.  The elevated plate version does work and a nice duplication is on the web somewhere - couldn't find it again, but it is basically a plate placed in the sunlight, a wire to the earth (grounded) and a capacitor between them.
Can't find it?  See attachment 2:
For the more adventurous - homemade x-ray machine:
http://www.noah.org/science/x-ray/stong/
(X-rays are no joke.)
Also, look at the comments made by SM regarding TAO's comments on the operating principles of the device.  SM stated that TAO was correct.  Read it over and over - think your winding needs a little work?
See attachment 3:
Starcruiser - good post.
        -Frank Edwards
starcruiser
Grumpy, I for one am not giving up just yet, just looking for answers.
My question is "What if the TPU uses a signal source to simulate the ambient or better yet to act as a tuned antenna?
I will continue to work on my current design and provide feedback on my progress.
Regards,
Carl
Grumpy
The TPU is source and collector.
Read the last two files that I just posted and read it again until you see it in your head.
        -Frank Edwards
EMdevices
Hi everyone,
I haven't been here in a while but it looks like the enthusiasm is high.  People are getting some results that are interesting.
I want to add a bit of perspective if it helps anybody.
1)  Coupling between coils at 90 degrees happens due to electrostatic induction.  (proximity to a  charged object induces charges on the surface of the other object)
2) High voltage in the control coils  (the segment coils)  is accomplished when the current is interupted and the magnetic field collapses rapidly.   This is your ordinary phenomenon used in automobiles to generate the sparks for the sparkplugs.
3) Since the sector coils, when they are "fired" or the magnetic field collapses,  have a high voltage develop on them, they induce charges on the collector coil, or the main coil inside the TPU  (some of you use 3 of these)
Here's a concept of "squizing the hose" like SM used a while back.
4) You "fire" each segment right after the other and the charge is shifted around the torroid.   The analogy was to fire each "cannon" in sequence, (this was SMs concept posted a while back)
Take a look at the diagram.  I show a linear line (or collector wire)  wraped with 4 sector (control) coils.    If one end is hooked to the other we have a TPU.
Now we just fire each coil in sequence and the charge is transported along the control wire to the output.
