user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
raburgeson
I've been trying not to post too much pics and leave server space for when we need it, I have some on the main thread, and a couple of scope shots also. I got to say 1 thing, everything does need to be geometrically correct. Everything has to be symetrical, all the cores have to have the same number of wraps, all the collectors ditto, I've even gone to the point of z-metering the capacitance between collector cores after the final global wrap. I have a bit of trouble getting the outer dimentions of the collectors right. I have rewrapped collectors time and again till they come out right. I've confused everyone with hidden conections on the ID instead of the OD. Very eye candy type of finish and wires can be much shorter, but more confusing to who ever looks at it. I recommend collectors be within 1/32 or 1mm.  I'll shoot in 1 and only 1 pic of my bench today. Just so X knows we aren't the free lunch line. I got little so far and have been sharing what I find. Someones got a patent somewhere, there's no selling this, and personal safety is don't hang onto anything. Get it to the people, and get some personal enjoyment and use out of it too.
for your enjoyment the question of the century
Is that a 2 giggle hurts compuker?
thought you might like that, not going to reveal the name of the girl that typed the original quire.
I'll get the other puter up and unload the camera.
Guys you color code the collectors so you don't get lost when you are changing your wiring config. I tried all black wire once, it was a nightmare.  It doesn't show but the center collector among the loose ones is green and black.
Mannix
I want to tell you something important that may help you to understand what is going on inside the collector.
You know what a particle accelerator is... Well you can accelerate electrons to past the speed of light and you know what happens? They disappear. Does that mean that there is no speed of light ? NO, it means that the electrons go out of this dimensional plane. Scientists are not prepared to explain anything beyond this point. Neither am I. However it has been hypothesized that IF the electrons did not leave our dimensional realm, and stayed here, they would rip the fabric of time and space, possibly destroying our universe as we know it. That means that the power released would be unbelievable and totally inconceivable to mankind. But never the less, it is fact.
My friend, listen. Think about, no, visualize the following:
Imagine that you have a cannon which fires a projectile at a velocity of 1000 miles an hour.
The amount of energy held in the moving projectile until converted is lets say a figure of ten.
It will never become more then our figure of ten. The energy will slowly dissipate until the projectile slows and begins to fall to the ground and it's finale dissipation will occur when it strikes the earth or the object it was aimed at. Now, we have been told that there will never be more energy available from the projectile other then what was given to it when first fired into the sky, EXCEPT for the following example:
Now, there can be a further dissipation of energy if the projectile was carrying a charge of dynamite to explode on impact as well.
Do you see how the different things all relate here?
Let me expand your mind for a moment....
Suppose that the projectile which you fired was another cannon? Now you have another cannon traveling at 1000 miles an hour... Now, if you could fire the second cannon, the projectile coming from it would be traveling at a velocity of 1000 miles an hour after being fired. However, since the cannon is already traveling at a speed of 1000 miles an hour when you fire it, the speed of the second fired projectile is essentially now 2000 miles per hour and the energy available to convert from the second projectile, is now twice the ten available from the first projectile! You now have energy availability of twenty to convert from the second projectile.
Now, what if the projectile fired from the second cannon were another cannon and you fired it. Since the second cannon is traveling at 2000 miles per hour then the projectile you fire from it would make 3000 miles per hour, and so on and so on....
The energy released from the speed of multiple projectiles increases the energy available to be dissipated upon impact many fold!
The faster the speed of ANYTHING the more energy will be available for conversion.
A long time ago, i said, if you take a bullet and throw it at the side of an automobile;e it will bounce off. However, if you place the bullet into a gun and fire it at the automobile it, with sufficient velocity, go through the metal door and through the other side because of the inertia energy available for conversion.
Speed is energy if you can convert the mass into energy quickly enough!
Anything no matter how small can store enough energy to convert into huge amounts of energy.
Even electrons.....................................
Now, electrons can travel only so fast along the surface of the wire because of magnetic flux. what if you disable the effects of the flux?
Now the electrons float freely without anything holding them back. electrons at the sped of light are now a possibility! How much energy can be converted from a stream of electrons traveling close to the speed of light? Remember the bullet story.
Think of this:
Energy conversion is different when you consider speed. 12 volts at 100 amps is slow and the energy can not dissipate quickly enough to kill you by discharge. But, it is a lot of energy especially if converted to speed. Reduce that 100 amps to 100 mA but increase the voltage (speed) to 100,000 volts and you can electrocute someone!
My unit operates on these principles. Think about all those frequencies traveling inside the collector coil and how they interact.....
lltfdaniel1
Thanks dave for this although i do not understand this stuff... as you can see,back on this forum that people are desperate, you should do more efficient secure ways of being undetected, such as,
1. Microsoft windows has MANY ways to spy On you,since windows is designed like that,
so ...
2, use computers that have not been online with your ip address,i am thinking of laptops,buy them used, equip them with wireless network card,(DON'T USE IT IF YOU HAVE PUT YOUR PERSONAL DETAILS IN IT , I MEAN THAT ,JUST PUT RANDOM BLAH INTO THE COMPUTER WHEN YOU SET UP OS OR WHATEVER OR FAKE DETAILS.)
3. Make sure its a complete FRESH install of windows,then do your recording on that and whatever documentation you wish to upload anonymously useing a NOTHER PERSONS WIRELESS NETWORK AND BANDWIDTH, USEing  THE LAPTOP(i suggest HIGH QUALITY PICTURES THAN VIDEOS,to save time uploading,and MAKE SURE YOU CREATE USERNAMES WITH THAT PERSONS WIRELESS NETWORK,to make it harder to track you), (OFFLINE,DO NOT GO ONLINE WITH YOUR IP HOME ADDRESS, BECAUSE OF MAC CODES)
4. After you finish upload - if you KNOW WHERE A WIRELESS NETWORK UN PROTECTED IS,and i would pick a wireless network thats quite far away from your home, i would put it as 10 miles Minimum or less if your comfortable with that, you could use those wireless networks at places like BARS,cafes,food places(and make sure its a UN EXPECTED RANT,And make sure you put in that you used a persons wireless network,and that would be as far i would go ), (MAKE SURE ITS CLOUDY - cloudy GOT THAT AND ITS DARK (if you plan on useing a persons wireless network, i would go with this one really,because even if you had not said ANYTHING,the guys still know what sites you have been by design with windows), IM TALKING ABOUT EARLY MORNING HOURS,and make sure there are no cameras,
So basicly, the first time you USE A laptop, you do this offline , put pictures on the hard drive to Upload , and also the documentation to upload to whatever sites, you can find and spam, while the battery lasts,and tell them to save it to their hard drives, and them tell others etc,etc , and THE OUTLET TO THE WORLD WIDE WEB WILL BE THROUGH WIRELESS, NOT YOUR HOME CONNECTION, NOO THATS A NONO NOT YOUR HOME CONNECTION, use somebody elses :-),and make sure you PUT IN , That you used a nother persons wireless connection, (i must add, that useing a wireless connection is illegal and can be fined some, if caught, but , if its something this important, then i would do it, if i had stuff which can help you or give you step by step to build a over unity machine)
sorry guys, its that hardcore.
And never go ONLINE WITH THAT LAPTOP WITH YOUR HOME ADDRESS,EVEN IF YOU CREATED A FRESH INSTALL OF WINDOWS,if you went online with it, then DON'T USE IT, and make sure where you buy a used laptop , make sure its kinda away from your home.
Thats a suggestion, but since mr x and Z, no DON'T Bother...............................for others who have keep Super quite and irritated, then this is a Way.
And since its likely, you would have used the world wide web to research overunity...... , it would be best to upload from wireless, Miles away from your HOME!.
Sorry for makeing this not to clear , but, ive digested other stuff than overunity....
so after all that,
its, Laptop with wireless, never be online with your Home connection(What i am talking about here is , when you buy a new laptop used or new,you do not go online with it,mmm and make sure if you can dodge buying it from a shop, mm buy it of a unknown person, ) , or others,
then its, upload the stuff you want to share(with wireless), mm USE High quality pictures(and if its a real machine make sure your generous with the PICTURES,), videos take time to upload,to whatever you want to send it.
and then never Go online with the laptop, mm even, make sure the laptop never be found,(MAC CODE)
also make sure your covered with your ID'S/Usernames/emails whatever way they can track, i would create usernames,emails (useing the wireless ,then usernames made with home connection or friends connection)
Rather than, HEY INVESTORS, I CLAIM A FREE ENERGY MACHINE, NOW RAPE ME!!!!!!!!!! *Suppressed , and threatened quite likely*
(even the camera..... i would not use it both,uploading to the home computer and laptop.....not even with a barge poll)
however if you have been researching the device(and are successful in replicateing mostly on your home computer with home internet), and then send out in high detail on how it works and how you can build one, they have a nother way, or narrowing down the search, to see which computer has been on these sites on such a machine to see if it matches IN A Mile radius,so if you research this stuff being very quite on the forum,then go to scotland for a holiday :-)  basicly far away from Home but then theres cameras ;-), you could take a bus with no camera,and pay by cash????
but in the states with the war on humanity, i think that would be hard.
or just desperately SEND OUT THE INFO SPAMMING, from home computer and i think, you should at least expect attention to big oil and big brother, mmmmmmmmmmmmmmmmmmmmmmm i wonder why ol steven marks has not said Anything, he said '' hey investors come and rape me'' doh, thats a lesson learned now,the GOVERMENT ARE HYPOCRITES!
And then it ends up as OVERUNITY electric being EVOLUTION, mmm
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
gn0stik
I haven't read the last couple pages, but I just found this post by marco in the hendershot related area of gn0sis.
im using the tesla magnifying approach.
now if i show my device, and say it taps the electromagnetic field of the earth, i would not be lying.
i just dont say i put in the energy in somewhere else.
now if i say it can be used to power water pumps in afrika, i would not be lying , since the scalar waves go anywhere.
if i truly suceed in making a device running on waves already present, that would be very intresting because we dont need to feed it anymore.
marco
So, it seems that marco and dave are using the MT, as SM conceded was the REAL operation of the device in his response to tao's "eureka" post. I guess you could call it. Why did it take so long to go in that direction..
Now this makes sense considering what dave posted. The frequency tests. They have acheived wireless radiant power transmission, now to tune the receivers to a natural power source.
getting the frequencies just right will be the trick, and making the receiver an "energy sucking" receiver, as Bill Beatty would put it.
Remember all that stuff guys? I know the old timers will.
So this also explains the pulsing effect in the video. Anyone else notice this? That was the MT feeding the MR that Marco was lighting the bulb with.
Suggested reading Konstantin Meyl's book.. Sorry forget the name.
I can post it later if I can dig it up. I know I have it somewhere. Also, Bearden's book, and if you have the "free energy secrets of cold electricity" by Lindemann, that would also be good.
At any rate, it's getting exciting. The pariah of science is being redeemed.
@Sam, I don't think anyone is planning on selling anything, maybe kits at some point would be logical, but I don't know of any plans to get rich off it.
Regards all,
Rich.
gn0stik
OK, so it turns out that Meyl's book is copyrighted and for sale on his website, so I cannot post it for everyone.. I can't remember where I got that, but I don't think I paid for it. It's called scalar waves, and goes for around 30 eu. There is also the experiment book which outlines build plans etc for his device.
Interesting enough the stuff that marco posted as turbo, is closely related to the topic of this book, and he did it shortly after I sent the book to him (I hadn't been to Meyl's site yet)
There are build instructions for a mini MT in the book and the experiments book.
So the lesson in all this is...  becareful about passing around stuff you found on the internet, it may be coprighted. Oops. I guess it turned out well.
Perhaps I should just send Meyl my 28 bucks.
Be aware that the book's original language is german, and the translation is rough at times.
http://www.etzs.de/onlineshop/index.php?language=en
