user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 18 Guests are viewing this topic.
raburgeson
I think the flux can be canceled around the conductor and this will not cancel the field around the coil. Drawing coils I came to the realisation that it has to be canceled in both directions. I don't have any collectors wound bi-filer guess my next step is to start winding. before I do can anyone think of anything else I can incorporate into the new coil? Should I fold the core, don't think it will hurt it.
Ok stefan, but if I hit a smoking gun got it circuit I'm posting a picture the size of Manhatten with everything labeled in type on it, Well 2 of them both sides of the board.
hartiberlin
Okay, Raburgson.
Well I just saw some postings of Otto
in gn0sis.com.
Here is what he wrote and he also now uses
bifilar output coils.
He also says, Turbo used Trifilar coils
in his video, where he lit the 60 Watts bulb...
Hello all,
of course your right. I would say my Rodin coil is one and is NOT a Rodin coil because I have 2x12 turns in my coil like Rodin did it but his coil has other dimensions (I think his hollow is much bigger). What I will say is I have only a bigger magnetic field with this setup. The power consumption from my power supply is with the classical coil 12VDC 1,8A = 21,6W and with the Rodin coil 5VDC 1.8A = 9W.
Why Im going this way??
SM said the TPU works with the earths magnetic field. We all know everything around us vibrates. This vibrations are in sine waves not in square waves and a Rodin coil needs sine waves to work. So I will pulse my 3 Rodin coils with sine waves and the control coils with square waves.
The next reason I use a Rodin coil is we are working with audio signals (20Hz - 20kHz we can hear, theoretically!!) with say, 5 kHz. Audio signals are sine waves (again sine waves).
Please dont kill me, I hate theories!!
Im now winding my collector coils.
This morning I saw Turbos setup at overunity. com. Now Im thinking...
His setup is trifilar with no segments. We have 3 collector coils, 3 trifilar wound control coils and if I make the outer coil (wound all over the others) in 3 segments...
Now I have really to think about this.
Otto
Hello all,
I cant post a picture because its only a ring like others and as I wound it I had to fix the turnes with isolating tape. The point is when I wound this Rodin coil I had to move the turns inside the hollow ring because my hollow ring is only 1 cm in diameter and the Rodin coil from J:L:Naudin is oval(7cm inner diameter, 14,5 cm outer diameter, HEIGHT 3, 75 cm). So I see my coil only as one with 12 turns and this twice as there are 2 coils of them.
Yesterday I wound 26 turns bifilar wires around this Rodin coil(s) to see what will happen (like turbo).
Guys I can tell you its the first time I lit a 24V/5W light bulb to full brightness!!! Its not much but this is my best result so far. The input fron my power supply was 9VDC/250mA and on the other side was the pulsed signal. The bifilar wound coil was connected in series. The frequency was in the range between 10 - 100kHz. I have the feeling if I could pulse the coil with higher frequency the result would be much better.
What I dont understand is why is the voltage on my power supply rising?? As long as Im working with my TPU very often I see the voltage rising on my power supply at some frequencies.
Yesterday with 9VDC on my power supply and pulsing the coil my volgage got to 24VDC or more on my power supply and then I lit this light bulb. I tried to stabilize this voltage at my power supply with diodes but nothing.
It seems to me my coil is powering the power supply?? This power supply is self made and stabilized 0 - 24VDC and can handle a lot of current.
Now, when I connect my Rodin collector in series and pulse it with one frequency and the bifilar coil with another I cant lit my light bulb. I also tried to use other combinations of pulses but only sine waves does the job!!
I forgot to mention I was using only sine waves (no kicks).
When I use square waves there is nothing. No effect.
Otto
raburgeson
Otto,
I was asking myself why the power was going up just before 3 bright sparks came out through the top of the case on my function generator, may it rest in peaces. Good luck I hope noone else has a similar experience. Is that DC or AC mine didn't last long enough to tell?
archon79
X tell me if this is on the right track,
You have managed to create a coil which can resonate with a nearfield frequency and generate electricity wirelessly. Like an electrical antenna.
But you have not yet found out how to get it to pull charge from the earths resonant frequency of 7.8
sparkman
Ran outa town cause he didn't like the treatment then came back to get even. He's still laughing!
