user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
c0mster
Im just following the master, Tesla. So many cool things to try, so little time.
Cam
tomas
Quote from: c0mster on December 13, 2006, 12:03:33 AM
Cam
hey cam that's an awesome video!
so you are basicly showing direct induction right?
Have you tried that coil with a little neon bulb on one wire and a frequency switch?
seems to be something there.
T.
otto
Hello all,
thanks for the ideas for a function generator. First I had such a generator woth one frequency, builded one more for the TPU and now I finished yesterday my third function generator. Im using a ICL8038. As I saw X uses this thing too but his shematic is not so complicated as mine. I have stable squarewaves, sine and triangle signals up to 100kHz but up to 1MHz this signals are not so good. The condensator for building such a frequency has to be high quality and such a thing I cant buy.
With this function generator I will today after work try to light my bulb. I will see what will happen.
The reason why Im using a ICL 8038 is I can have sine waves!! Steven Mark said the TPU works with the earths magnetic field. The Schumann resonance and all in nature is vibrating. Thats OK but I think everything is vibrating in sine waves not in square waves!!!
Never mind I have a chance to use square and sine waves.
A time ago I used in my TPU square waves at resonance and then I switched my function generators to sine waves and saw the current dropping. Also at some frequency I had a hum noise comming out of the TPU. I was using just two frequencies.When I heard this noise I thought something is vibrating and surched what this was but find out my TPU makes this noise.
Otto
Dingus Mungus
EMuntinga
hello guy's
i read the post for a wile and i think i have a nice and cheap solution.
it is a square wave from 0 to 1.5mhz
look at the schematics
drive it with a totempole and drive a fet
i tested the circuit and it is working perfect
so lo cost and built many as needed
greets
ernst muntinga
the netherlands
