user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
Grumpy
I was refering to Turbo's TPU, not his coil.
Quoteso this would be the most simple coil.
it is not the most powerfull ring.
the wires do get hot.
it cancels the fulx in a certain way the electrons are free to move.
it still does need a 9 volt battery for the OSC.
it needs to speed up a bit without the load otherwise it wont start at all.
no magnets are used.
Don't think Turbo's board is spitting out 3 frequencies.
What do you get when the 3 fequencies mix - hmm looks like a positive pulse.
What sort of majical phenomenon can you imagine coming out of 3 frequencies mixing together?   Think about for a few minutes.  What could the waves possible do in any realm of physical reality?
Also, why all of the SM references to Tesla, why the reference to shockwaves?
What are "kicks"? - indirectional pulses.
How do they kick particle energies up with in accelerators - kicks - which are pulses (damn big ones too).
The following was posted and then deleted - Tao had the secret months ago:
Quote(from TAO) So, based on those things, lets look at the Mark device. Lets say Steven put one big stout cable around or in the rings,and all around these he had many many windings. Now, if Steven put into that stout cable a current and before the current could get to the end of the wire, he stopped it's flow abruptly, then perpendicular radiations (the KICKS), the same Tesla observed, would appear and spread from this stout cable, this would cause Tesla'a copper charging effect, which would hit all the other wires in Steven's coils. Now, if Steven wired the coils right and stopped the discharge of the current through the coils he would be able to extract a lot of extra energy from the tap points on the coils. This is basically how Tesla's magnifying transmitter works.
Capacitors discharged ABRUPTLY into a wire, then the current flow is stopped ABRUPTLY before the current makes it to the end of the wire, and this KICK comes out of the wires perpendicularly. This KICK would then charge copper with electrons(hot electricity) or their opposites(cold electricity). It just depends on how you setup the device.
So, I would say that Steven's KICKS have a direct relationship to Tesla's Magnifying Transmitter, its REAL operation.<
So Lindsay, this guy definitely has the secret. I do not know if he will be able to duplicate power generation, but he does have the secret.
Do you think he knows it?
The only part he doesn't have any idea about is that by starting the oscillation you cause the current to flow in the collector which causes the magnification of the process within the collector which will ultimately produce the greater voltage and power in usable amounts during operation.
Do you see anything in this quote about 3 frequencies?
Furthermore, someone else is using pulses and getting results.  Maybe he'll post something soon.
        -Frank Edwards
lltfdaniel1
You know what irritates me,
From God,
Matt. 24:22 And except those days should be shortened, there should NO flesh be saved: but for the Elect's sake those days shall be shortened (by Divine Intervention).
What do you think that means?
Utter your thoughts here is some input,
The Rule of the universe can see where every atom goes, and then able to see visions of the future, so ....from what i digested , this is a matrix of mathmatics,we are in, called the covenant,so to me ''i am'' is allowing this reap what you sow,so basicly the gate for overunity under satans will is basicly closed.
Read about Isaac Newton please.....click below link...
http://jahtruth.co.uk/newton.htm
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
CTG Labs
Like I said, I am only passing information from SM about how to see the basic effect with something simple and practical to build.  Do with it what you will, or follow your own path.  I prefer to follow the path SM has told me to see the basic effect, of course you can choose which ever path you like.
D.
CTG Labs
Sorry I am not sure how this relates to TPU research?  Is this a church or an technical forum?  No one here is going to be recruited, sorry.
lltfdaniel1
Quote from: CTG Labs on December 13, 2006, 04:19:08 PM
If your able to use that eye, overunity is not chance,i can see what is irritateing me,i just wanted to give my opinion out......because its about struggleing to prevail where, the secrets are hidden.
If you use your eye,on that and examine it like you do with over unity ,because this technology given was given the go ahead back in heaven by the person who Designed that page.... .. .
You can read more if you willed,but im not asking, but im Pointing out.
