user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 18 Guests are viewing this topic.
juice
@mrl:  That Harmonic Frequency Generator sounds intesting. Start a new thread when you get things going!
Groundloop
aether22
Why he DIDN'T FAKE IT.
How likely would you be to fake such a thing, he's been working on this stuff for what, about a decade, has a website and has joined 'The Ranch Project'.
He is very very unlikely to fake this.
Furthermore how did he fake it? the LED in the light bulb trick?  Well maybe but it appears to only be on as he makes contact with the wires, it acts the way you expect with it flickering as contact is momentarily lost.
Also he only said that he wanted to raise spirits and that it wasn't Free Energy, and that it was not a reliable effect, sometimes it just worked and sometimes it just didn't, if he was admitting to faking it he wouldn't have said the latter.
Also if he way faking it, would he have gone on to build so many different versions?
I mean he has now build quite a few versions.
And Otto has apparently had results:
Hello all,
I just lost a post, I will try again
My input power was 12,5V/950mA from the power supply measured with a ANALOG voltmeter and ANALOG ampermeter.
The signals measured on my 60W light bulb was around 160V and without bulb around 170V. This was measured with a scope HAMEG 208 (2x80MHz). I did NOT measure the current at my bulb.
Otto
So I think it is solidly unlikely that Dave was saying 'I faked it' an Lindsay and Marco suggest.
Now I do hope he will answer some more questions, but this just doesn't add up to a fake to me, at least not if you don't doubt Free Energy and the reality of the SM device.
no time to spell check
Groundloop
hartiberlin
This is , what Marco wrote me again:
yes the reciever is in the capacitive field just like my hand reaching the coil with the light in one of my early video's, just at that time i saw the field was there but i didnt know what it was, it seems to be evrywhere.
so i create a big controllable dielectric field , much bigger then the magnetic part, and i believe this is orgin of true (natural) electricity.
its a system ground just above real ground, then the bird, then another system2 ground above.
im seeking to use more foil at diffrent angles/times to see what it does.
anyway it has to be lmd.
but i guess you figured that part out already
the first coil was a disaster giving me a lot of shocks and the transmitter had to be verry close, like in direct coupling, with alot of loss.
so , no overunity there, i never claimed it too.
but by making that video i discoverd the negative potential
so when doing such experiments im always surprised by new unknown happenings, and this does take me further.
by showing my work most of the people think i have it all or so, but its a long way and i only want to show im making progress.
And he added today:
i already posted it over on your place how it works...
i posted it right after i showed the video.
nobody read it i think.
did you see my drawings on the tpu?
they are horrible.
i cannot even draw a normal coil.
when i have a spare minute i will try to draw something, this always takes a long time for me because it's always wrong so i have to start over 10 times.
i have a table, it's on little wheels so i can move it.
so there was one foil under the table just above earth ground.
then on the table the bird.
then above the bird the second foil.
double impulse currents between the foils creating a very heavy potentional diffrence with and without ground and a resonating bird.
when you touch a foil which is disconnected the surface is verry smooth.
when it is higly charged and you move your fingers over it you can hear the frequency and the surface is "sticky" not smooth at all.
when you use a grounded circuit the 50 or 60 Hz comes thrue , when u use no ac grid it's just the frequency of the generator.
ensure the frequency is high enough so you wont get shocked.
oh, and open the windows for fresh air when it begins to shizzzz.
also ground and shield the cam if you want to film it otherwise it will freeze.
Marco.
