user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
MeggerMan
Hi Alex,
OK, have you tried to split the supply for the mosfets and the pulse circuit?
Have you tried a single pulse only and see what output you get?
Can you scope the input of a single pulse and the output so I can see what the results are.
Rob
Groundloop
MeggerMan
Hi Alex,
Has your scope got storage, that helps load for taking photos.
Yes, run a single 555 so you can monitor the effect of one pulse input only.
In theory even with one input, you should get some kind of output.
Ideally it would be nice to see 80 to 90% of the input as output, but because the windings are at 90 Degrees and that there is no ferrous core material, that may not ever be possible.
If you have any op amps kicking around you could build a pulse width control circuit.
Those using Ubuntu "Edgy Eft" (Linux) like myself, the spell checker for firefox 2.0 is such a help.  ;)
Rob
Groundloop
Grumpy
wacking a coil with several amps will only create an empty fire extenguisher.
more output = higher voltage
Voltage too low - kick it up - several circuits around for "voltage multipliers" - passive components
        -Frank Edwards
