user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 28 Guests are viewing this topic.
aether22
Possible connection:
According to this site I was just looking at. (it's on geocities and has exceeded it's BW so checkout the archive: http://web.archive.org/web/20001007150538/www.geocities.com/CapeCanaveral/Lab/1287/markp6.html)
'Tesla and others claim because of the speed differential, energy is obtained. It takes longer for the energy to get through the coil therefore a differential is established.'
Now I have an even better explanation as to why these devices have such 90 degree windings and the evidence is overwhelming, however it is possible there is something to this delay thing also.
I think SM mentioned having 3 collector coils and encouraged testing all possibilities of series and parallel including 2 in series and the other in parallel, well this delay line idea might explain that.
Furthermore I think I recall him saying something about the gyroscopic effect happening only when you have 2 something. (flows, rings, fields I forget)
Also do look into the Markovitch device, it is clearly similar to Steve's device, it can output at least 500 watts and has DC induction which in one of the many wiring configs apparently used is an open circuit! (not the first time I have heard of low voltage DC flowing open circuit)
Between the site above and info on RexResearch, there is enough to replicate, and as it isn't powered at all and the output is DC any energy out is successful functioning, and from the test results it is clear that it is capable of outputting low energies as well as high, which might not sound like a good things except that means you can have a small level of success which is better than getting ziltch until it comes to life big time, so you can improve this device and watch the results from each tweak. Plus it appears to have been replicated at the time.
otto
Hello all,
today is a new day and my post about my kicks of 240V are no more valid.
My kicks are now over 400V!! with a load of a 40W light bulb measured with my scope. This scope can measure 400Vpp but my kicks are bigger. My screen on my scope is full of vertical lines. Today I will connect a 100W light bulb but I think the kicks will not drop.
Now the wire sizes of my TPU:
Collector coil(s) - each
lenght of the wire 60 cm
diameter of each wire 0,22 mm = awg 31
diameter of 1000 pieces = 1 cm
1000 pieces in paralel
I have now 500 pieces in paralel and the result is the same
If I would have 10 or 20 of this wires the result would be the same!!!
SO DONT MAKE THE COLLECTOR COILS LIKE I DID IT!!! NO NEED!!!
Control coil(s)
4 segments
each segment
170 turns
diameter of wire 0,5 mm = awg 24
lenght of 1 turn = 3,3 cm
1 segment has a wire lenght of 5,6 m
170 x 4 = 680 turns for the control coil
lenght of the wire for the complete control coil is 22,4 m
Outer coil (Feedback coil) - coil wound over all the others
4 segments
each segment
56 turns
diameter of wire 1 mm = awg 18
lenght of 1 turn = 14 cm
1 segment has a wire lenght of 7,8 m
56 x 4 = 224 turns for the feedback coil
lenght of the wire for the complete feedback coil is 31,3 m
Dimensions of my TPU
outer diameter 14 cm
inner diameter  10 cm
height 5 cm
This should be the 6" TPU.
Otto
aether22
Otto, Do you get any net DC with the setup I suggested? If so what voltage?
Does the bulb glow (and if so how bright?) and how much power are you inputing?
And do you feel ant slight vibration, gyroscopic or resistance to motion effects from it assuming your able to handle it when it runs.
Also are you using a wood core as SM did or just winding wire around wire? There is a good chance it's important to use a wood core as SM does.
You sure are getting impressive results.
otto
Hello,
@aether22
if I understand right I have to connect ONLY the pulses without a + to the coils as you discribed??
If so I think there will be nothing.
With my setup my power supply gives me 12-13V/500-900mA (depends on frequencies) and the square waves are 4V.
My 40W bulb is glowing very nice but not full brightness.
In this moment there is no vibration. I expect a huuum noise when I get the right frequencies because I heard this noise and lost it. A month ago I measured the weight of my TPU and then switched the power and pulses on. Because I was on a low frequency I saw the weight of my TPU was changing and this means for me the TPU in full work will loose weight.
My insulation between each of the collectors is made of cork plates 5mm thick.
Otto
Groundloop
