konduct
I've got some roller switches I think will work to fire the solenoids.  I figure I can put them at an optimum height and let the pendulum control the timing.  From what I understand, a pendulum's oscillation time remains constant, regardless of its "amplitude".
supersam
hey konduct,
i am thinking two different bicycle gear setups on either side of the center shaft at the fulcrum, then you can gear with the bicycle gears the output to the pendulum one way and use any excess out of the otherside of the shaft geared differently to use up the power spining the flywheel setup brian sugested to help boost the flywheel.  with brians setup you can also use the bicycle gears to speed the flywheel to make extra power.  does any of this make since?
lol
sam
bsrinon
Below is another diagram with a real bike. This is what I had in mind.
Yes we should make use of both up and down strokes so energy is not wasted.
To make use of the downstroke, maybe the energy can be stored in the spring as in the diagram. This is what is in the pump invention. I think it had two springs.
Brian
bsrinon
By the way, maybe the front suspension should be replaced by a solid fork!!!  ::)
supersam
NOW!
stupid question of the day, why can this not also be used to overcome the sticky point?  some of you magnet guys need to jump on this!!!
lol
sam
