0 Members and 23 Guests are viewing this topic.
supersam
brian,
nice setup, however if you don't want to swing the pendulum, we have got to figure out some way to swing the pendulum, when we are not around.  i think your idea of having a selinoid kick it is great, but what are you going to do with the excess mechanical energy?  boy doesn't that seem like a stupid question?  but at 12:1 there have to be some answers to something.  i know my system wastes it in mechanical energy, due to friction, and other mechanical problems, but all the energy must be used in the end!!! i was only trying to close the loop for now, and then start working on extra efficiencies for an overunity system.
lol
sam
bsrinon
Sam,
To keep the pendulum swinging while we are not around, I was thinking of using a sprinkler solenoid like this:
http://www.starnursery.com/images/items/938401.jpg
The power from a generator on the back wheel could power this solenoid.
Maybe a generator like this can fill up some capacitors to power the solenoid:
http://www.aztlanbicycle.com/images/products/lowrider-accessories/series-00123-lights.jpg
Brian
supersam
brian,
don't get me wrong,  maybe two setups like yours will be best.  i just wanted to take advantage of the power on the upswing and the downswing of the lever.  i had posted a stupid idea at the top of page 3.  that i have since gone back and made a smiley face because i couldn't figure out how to make the single direction bicycle crank work in both directions, maybe you have come up with the solution.
i don't think milkovic ever used the spring for anything but providing a, LOAD, to keep the machine running optimally.  if we can figure out aq useful way to load the machine without a spring, then?  if you think a spring is helpful, then two springs, added to our setup as in the earlier post on this site might be something to consider in conjunction to these other things.  in other words i don't see having a top and bottom spring driving a circuit could hurt anything with 12:1 input to output.
is any of this making any scense?  is a hybrid the way to get to overunity?  can it be done with one disciplen alone?  it seems nobody is getting there by themselves, but alot of people are getting close!!!!!
lol
sam
supersam
hey everyone,
i guess what i am trying to convey is the old story of the man with ten sons.  the old man passes a bundle of ten sticks tied togeather around to each of his ten sons, and asks each of them to break the bundle.  of course none of them is able to do so.  he then takes the bundle apart and hands each of them one stick to break, and all ten of the sons is able to break his stick.
i guess my point is in which case did the work get done??
lol
sam
pg46
Hi All-
If you want to run a generator why not use what the inventor demonstrated in his videos - the hand held flashlight dynamos?
They can produce power from the verticle linear motion and can also be used as a spring. You can place them under and above the lever to take advantage of both strokes. You can tie as many together as you would require to increase the spring strength and to increase power production levels.
These flashlights are made in large quantities in China and are inexpensive to buy.
Just A Thought
