Merg
...news from veljkomilkovic.com:
Theory of Gravity Machines - Gravitational Field As a Fuel
Jovan Marjanovic -- Theory of Gravity Machines -- New Breakthrough in Physics of Two-Stage Oscillator
This work is a presentation of simple theory of using conservative gravitational field as a fuel. In order to extract energy from conservative field, gravity shield effect is necessary. With proper usage of the shield, variable gravity field should be created in part of a system. Energy can be extracted only if difference in potential exists between two poles. The logic of this theory will also be used to explain two-stage mechanical oscillator of Veljko Milkovic and areas of its improvement.
Key words: gravity machine, gravity shield, over unity, pendulum.
The complete paper can be read on the next link (PDF - 122KB):
http://www.veljkomilkovic.com/Docs/Jovan_Marjanovic_Theory_of_Gravity_Machines.pdf
Merg
Pendulum Generator
http://www.youtube.com/watch?v=JvxwnE9Iono
"Genrator pendulum weight which means turning 360 degrees can produce a movement which is applied to an electric generator, this system increases the speed tilting more and more, which should be controlled by a braking circuit magnetico.CESrevolucion. Inventer Argentinean"
Omnibus
Quote from: Merg on August 16, 2010, 11:24:35 AM
Pendulum Generator
Sounds like Bob Kostoff's claim. The video is as murky as his, to say the least. What is this all about? Can there be more details given so people can reproduce it -- it's claimed to be a self-sustaining device, right?
Merg
Quote from: Omnibus on August 16, 2010, 11:59:33 AM
I've just found it from YouTube search.
Here is another video from the same guy
http://www.youtube.com/watch?v=QhEqB0k8Ops
Omnibus
Thanks @Merg. You don't know who this guy is, right? Like I said, this is very similar to Bob Kostoff's early claim. Recall Bob Kostoff later recanted saying that he's actually using compressed air. Wonder what the story here is?
