0 Members and 83 Guests are viewing this topic.
ltseung888
 Let us focus on the Seesaw system in the video.
The Weight W1 was 74 pounds.  The Pendulum bob W2 was 46 pounds.
Let us assume L1 is equal to L2.  From the video, L1 may be longer than L2.  In no motion state, the anti-clockwise moment is 74 x L1 and the clockwise moment is 46 x L2.   Anti-clockwise is much larger and the Weight W1 will not move.
When the centrifugal force (Fc) is large enough, (W2+Fc) x L2 can provide greater clockwise moment to lift the weight.
In the seesaw as shown in the diagram, the potential energy gained by W1 is W1 x g x h.  One can argue that the potential energy loss by W2 is W2 x g x h.  There is a net gain of (W1-W2) x g x h or (74-46) x g x h or 28 x g x h units.
Where does this energy come from?  It comes from Tension of the String.  This energy is used to raise the Weight W1.  The Lee-Tseung lead-out theory argues that this is the Lead-out Gravitational energy.  This amount of energy is brought-in to the system.  This additional energy makes the Milkovic 2 stage Pendulum shown in the video Overunity.   (An example of a Lead-out Energy Machine.)
Not every 2SO system is overunity.  If W1 is less than W2, we do not have a net gain of potential energy.  If L1 is shorter than L2, we may not have net gain of potential energy.
In the video, the Weight W1 is actually lifted and this work can be attributed to Gravity.  Traditionally, we can use gravitational energy continuously in form of Tidal motion.  Now we can use gravitational energy lead-out in the Milkovic 2SO system as shown!
Cheers to Milkovic, Raymond Head and all the contributors.  They all look (at the video) but how many can see (that the system is already an overunity device).  The greatest secret is now revealed.
God Bless.
ltseung888
 The Impact of "seeing that gravitational energy can be led-out or brought-in by oscillating systems such as the Milkovic 2 stage Pendulum".
1.     It should now be clear to many who looked at the video that the energy of the lever or seesaw system is NOT transferred from the pendulum system.
2.    The raising of the Weight W1 is done via the increased Tension of the pendulum string.  The increased Tension is a "free" consequence of the oscillation of the Pendulum.
3.    The increased Tension raised the Weight W1.  That energy can be regarded as Gravitational Energy.
4.    The Lee-Tseung Lead-out Energy Theory treats that as Lead-out or bring-in energy.  The Input energy plus this Lead-out energy should be regarded as providing the total energy to any system.
5.    If Gravitational Energy can be lead-out, Magnetic Energy must be able to be lead-out.  The reason is that we can always use a permanent magnet as the pendulum bob and place other permanent magnets to increase the attraction.  With magnets, we can also use repulsion, shielding, change direction and strength of the magnetic field.
6.    The pendulum system can be replaced with an unbalanced wheel with the added advantage that the period of oscillation is not governed by the length of the string but by the speed of rotation.
7.    Pulse force on a balanced wheel where the rotational energy is extracted has similar characteristics of an unbalanced wheel.  A constant rotation flywheel can store energy.  Pulse motors such as 225 HP, Bedini etc can lead-out electromagnetic energy.
8.    No moving part machines with flux changes only via electric circuits can theoretically lead-out electromagnetic energy.
9.    Electromagnetic energy is associated with the Electron Cloud Energy surrounding atoms and molecules.  Using such energy is akin to using chemical energy.
10.                       Getting zero point energy is no longer abstract.  The thermal energy at absolute zero degrees may be nil.  But there are always gravitational, electromagnetic energies from the many stars and planets.  Now we can use such energies.
11.                       Alternate Energy research and development will become respectable.  The Milkovic 2-stage pendulum is likely to be replicated and treated as a standard teaching tool at all Universities.  Milkovic is likely (and deservedly) to win the Nobel Prize.
12.                       Governments will pour in millions or billions of dollars in such research.  Products will no longer be national secrets.  For example, the 225 HP Pulse Motor will be made available to the General Public.  The energy crisis is over.  China (Hong Kong) is likely to become the Mecca of Alternate Energy Research?
How many who have been Looking can now See?  Is the great secret revealed?  Do I need to post more?
Divine Revelation?
ltseung888
Simple but conclusive experiment to show that Tension increases with oscillation amplitude.
If increased Tension is reponsible for lifting the weight W1, where does the energy come from?
Any model must answer this question!
Have you been looking?  Can you see now?
Divine Revealation opened my eyes after 10 years.  The great Open Secret is explained.  The Milkovic 2SO is a clear example of Lead-out energy.  Gravitational Energy is brought into the system.
ltseung888
 I just finished a good meeting with an overunity energy researcher in Hong Kong.  He sees the workings of the Milkovic 2SO now and knows why a large prototype such as that from Raymond Head is necessary.
He said: "Centrifugal force depends on v*v.  The higher the velocity, the better will be the prototype in leading out gravitational energy.  Most experimenters scale down linearly.  No wonder thousands of experimenters cannot see."
He continued: "If you cannot get the 225 HP Pulse motor from USA or China (for demonstration), you can try those recommended by Sterling Allan.  Just pay. (You are too old to build any prototype yourself.  He was polite.)
From Sterling D. Allan site:
http://peswiki.com/index.php/Main_Page
Prototype Product from Russia:
http://mes50hz.ru/index_en.php
Prototype Product from Turkey:
http://peswiki.com/index.php/Directory:EKA_Elektirik_%28Electric%29_QMoGen_in_Turkey
Prototype Product from Quanta Magnetics
http://peswiki.com/index.php/Free_Energy_Blog:2014:08:30#G1.27s_Gyroscopic_Resonant_Inertia_Pulse_Motor_Generator
ltseung888
 Extracted from Patrick Kelly's Book:
http://www.free-energy-info.co.uk/Chapter4.pdf
As there is excess energy, there appears to be no reason why it should not be made self-sustaining by feeding back some of the excess energy to maintain the movement. A very simple modification to do this could be:
Figure 4 – 25 (attached)
Here, the main beam A, is exactly balanced when weight B is hanging motionless in it's "at-rest" position. When weight B is set swinging, it causes beam A to oscillate, providing much greater power at point C due to the much greater mass of beam A. If an additional, lightweight beam D is provided and counterbalanced by weight E, so that it has a very light upward pressure on its movement stop F, then the operation should be self-sustaining.
For this, the positions are adjusted so that when point C moves to its lowest point, it just nudges beam D slightly downwards. At this moment in time, weight B is at its closest to point C and about to start swinging away to the left again. Beam D being nudged downwards causes its tip to push weight B just enough to maintain its swinging. If weight B has a mass of "W" then point C of beam A has a downward thrust of 12W on Veljko's working model. As the energy required to move beam D slightly is quite small, the majority of the 12W thrust remains for doing additional useful work such as operating a pump.
*** For all his knowledge and insight, Patrick Kelly may also be looking and not seeing.  His comments and improvements are always to be admired.  Will someone inform him of this great secret?  All his work is well justified.
