ltseung888
There will be a Chan Wheel in the coming days.  The Chan Wheel may be the XXX wheel if no one else builds a similar device.
Mr. Peter Chan, a retired mechanical engineer, has bought an old bicycle and took it apart.  He should be able to build two Chan Wheels.  Once he bought the other parts, he would be able to build the XXX wheel.
The first step is a simple demonstration of the Milkovic 2SO except an unbalanced wheel would be used.  The attached diagrams show side and top view of this set up.  Both the lever arm and Frame have "holes" so that the set up can be adjusted or tuned.
The second step is to add the crankshaft and bicycle chain.  A much simplified crankshaft than the picture is sufficient.
The Chan wheel will be available for all to copy and replicate.  It will be announced to the World after running continuously for two weeks after one pull.
The World Energy Crisis is coming to an end.
Paul-R
Quote from: ltseung888 on October 07, 2014, 08:12:32 PM
I could not access my hotmail account this morning. Someone doing hacking?
Hotmail is notorious for difficulties of one sort or another.
Has your account been sending out spam to other people without your knowledge?
Have you changed your password recently?
Do you have a password which is a word in the English language or any other language?
Do you have an item of punctuation in your password?
ltseung888
Simplified Chan Wheel crankshaft mechanism.  People in 17th Century should be able to design it.
The attached mechanism should be constructable in the 17th century.  It may not be very efficient.  With proper machining and lubriation, it may drive the bicycle chain and the unbalanced wheel continuously for 2 weeks?  Most machine shops in Hong Kong or China should be able to do it.  The actual bend need not be rectangular.  The shaft need not be one piece.
Anyone with better ideas?
ltseung888
ltseung888
Proposed simple crankshaft part design.
I think that we have the basic information on the Chan Wheel now.
There will be much testing, tuning in the coming days.  The chance of one pull and the Chan Wheel keeps rotating for 2 weeks more is 99%.  The Lead-out gravitational energy should be able to overcome friction and air resistance.
You can start now.  Or wait for exact dimensions after tuning.  Or order from Mr. Peter Chan later.
The draft presentation file is attached.
