ltseung888
 From Chapter 4 of Patrick Kelly's book
http://www.free-energy-info.co.uk/Chapter4.pdf
John Bedini's COP=8 Pulsed Flywheel.
The Chas Campbell system is not an isolated case. On page 19 of the book "Free Energy Generation - Circuits and Schematics" John Bedini shows a diagram of a motor/generator which he has had running for three years continuously while keeping it's own battery fully charged.  (Bedini1.jpg)
The general strategy is that the motor spins the flywheel and the flywheel shaft spins a disc with permanent magnets mounted on it. The magnets have their South poles facing corresponding helically wound coils which are connected in series. As the magnets pass by the coils, a voltage is generated and current is then drawn from the coils and fed, first to the motor to power it and then secondly to the battery to keep it charged.
John shows his switching mechanism as a mechanical attachment on the flywheel shaft with a conducting sector of about 110 degrees of arc. This gives equal duration pulses being fed back to the motor and then to the battery, with there being a short gap between each pulse and the following one.
Patrick Kelly correctly suggested the addition of a geared mechanism (Bedini2.jpg) I would further suggest to use an unbalanced flywheel rather than a normal balanced flywheel.  The pulsing effect will bring-in much more gravitational and electromagnetic energy.  (That has been demonstrated by the Ting Wheel).
Furthermore, the arrangement in reply 2255 produces a much stronger magnetic field than the disc with magnets as shown here.
ltseung888
Ting Wheel Overview:
1.  Use large coils to provide strong magnetic field.  Has excess pulsing power.
2.  Use unbalanced wheel mounted vertically to provide additional pulsing and bringing-in gravitational energy.
3.  Use chain mechanism to pass energy from main shaft to commercial windmill generator unit.
4.  Commercial windmill generator provides power plug outlets (220V) and Recharging Battery circuits.
5.  Aim to provide 5KW for home use.  Energy comes from 12V battery, Lead-out Gravitational and Electromagnetic Energy.  The last is the main source.  The last can also be thought of as Electron Cloud Energy.
ltseung888
 There is the concept of Zero Point Energy as advocated by inventors and authors such as John Bedini, Tom Bearden,Thomas Valone, etc.
The term zero point comes from the thermal dynamics concept of absolute degree zero.  At such a temperature, there is supposed to be no thermal energy.  However, there are still other forms of energy such as gravitational and electromagnetic energy. If we can use such energy, we are effectively using zero point energy.
The Lee-Tseung lead-out energy theory and the Chan Wheel demonstrate absolutely and conclusively that we can bring-in gravitational energy continuously.  That also leads to bringing-in magnetic and electromagnetic energies.  The obtaining of energy from Zero Point (or quantum vacuum) is a scientific certainty.
This may be slightly different from what the authors originally think...
Divine Revelation.
ltseung888
Photo of Chan Wheel as of Oct 17, 2014.
The first Chan Wheel was designed to obtain test data.  It also served two important functions:
1.  Is the Unbalanced Wheel equivalent to the Pendulum?
2.  Can a baloanced wheel lift Weight W1 and lead-out gravitation energy?
The conclusion from the experiment is:
1. Yes. The Unbalanced Wheel is equivalent to the Pendulum at low swinging amplitude.  At higher rotational speeds, it is much better than the pendulum in leading-out gravitational energy.
2. No.  A Balanced wheel cannot lift Weight W1.  This is the reason why adding an unbalanced wheel to the Ting Wheel increased the output from 300 watts to 5,000 watts. (I believe that that Tong and Bedini wheels will bennefit from this feature.)
The videos will be edited before publishing.  The second version of the Chan Wheel will have the feedback mechanism (cranksaft and chain).  It should be out shortly.  Be patient.  The World waited over 300 years to learn the secret of the Bessler Wheel.  A few more days or weeks would not make much difference.  The second version of the Chan Wheel is expected to run forever.  I plan on two weeks continuous running before announcing to the World in a big way.
God Bless.
QuoteThe Lee-Tseung lead-out energy theory and the Chan Wheel demonstrate absolutely and conclusively that we can bring-in gravitational energy continuously.
No, they don't.
QuoteThat also leads to bringing-in magnetic and electromagnetic energies.
No, it doesn't.
QuoteThe obtaining of energy from Zero Point (or quantum vacuum) is a scientific certainty.
Please feel free to cite some scientific references for the _obtaining_ of energy from the "zero point".
