ltseung888
At my age and experience, I start to like Fixtheworldproject.org more and more.
Their philosophy of disclosing and sharing what they know even if that is incomplete starts to excite me.
The Milkovic 2SO is already an overunity or lead out energy device.  The swing amplitude does not decrease when the weight is lifted.
We just changed the pendulum to unbalanced wheel and we have the same effect.  In other words, we already have an OU device in the form of the Chan Wheel.  If we stop at this stage and tell the World, almost every garage mechanic can have an OU device.
All we need to show is the horizontal pendulum and every scientist will know that they can lead out magnetic or electromagnetic energy.
The more exact theory is that we lead out the Electron Cloud Energy and thus do not violate the Law of Conservation of Energy.
Do we actually need to build a 5KW electricity generator ourselves?  Can we entrust that job to the younger generation?  Some produced the 225 HP Pulse Motor and their work became
"top secret".
The commercial dollar sign kept the Tong, Ting Wheels confidential.  That is likely to make the rich richer.  Is that the Divine Way???
I shall devote effort in making the QEG the 5KW open source unit.
Void
Quote from: ltseung888 on November 16, 2014, 10:32:43 AM
I always use DC to get resonance in tank circuits.  In the QEG set up, the exciter circuit apparently uses AC.  Am I mistaken?
With AC, there is always pulsing in the opposite direction.  If this is not perfectly in sync, it is like someone pushing the swing back at you before the maximum amplitude is achieved.  The swing may still move but not at its highest efficiency.  Line AC is at 50 or 60 hertz - not 400 as designed.
QEG founder James already stated that the plan he got from WITTS were not complete.  He had to modify and innovate.  May be the lack of sufficient output to provide loopback is due to using AC instead of DC?
We changed the pendulum to unbalanced wheel on the Milkovic 2SO with excellent results.  Can changing AC to DC work similar miracles with QEG?
Hi Lawrence. For the QEG, they were trying an antenna and an earth ground, which if not rectified using a
diode or diodes, would be picking up AC signals. I am not sure if they are still trying this approach or not.
To drive a tank circuit with DC, you would need to consider the following.
When you have a tank circuit, i.e., a capacitor and inductor (coil) in parallel, you cannot
apply DC (positive and negative leads of the DC source) directly across the tank circuit because the coil in the tank
circuit will be a short circuit to DC. This is true if the spark gap is also parallel to the tank circuit. However, if the
sparkgap is in series between the capacitor and coil, then if you have a high enough DC voltage to
cause the sparkgap to arc over, you can then use DC to continually charge the capacitor and to fire the
sparkgap at fairly regular intervals determined by the current capacity of the HV DC source and the
size of the capacitor. This is a common way that the primary coil of a tesla coil can be driven using a
parallel capacitor and sparkgap in series, for example.
See the attached schematic diagram to see how this would work.
This diagram shows a HV AC signal being rectified to HV DC first using a HV bridge rectifier diode arrangement,
and the resulting HV DC is then used to charge the capacitor. If you already have a HV DC source, you don't
need to rectify to using the bridge rectifier diodes.
All the best....
ltseung888
Shall work with others in Hong Kong who are interested in the qeg.
ltseung888
We know that the Milkovic 2SO leads out gravitational energy when the centrifugal force plus weight of the unbalanced wheel produces higher moments.  The observable effect is the lifting of the Weight.  It occurs at a given frequency (resonance)?
What is the observable effect of the QEG?  Is it just the brightness of the light bulbs?  If the energy comes from the Electron Cloud, will there be other signs?  Will the laminated core go into physical vibration?  The laminated core is the most likely place to be influenced by Magnetic flux?  Is the louder noise from the physical vibration of the laminated core?
If that were the case, are there other ways to get the laminated core to vibrate and get into resonnce?  Can a transformer type set up do it?  Is the Steve Mark Type device a type of transformer set up?
In Stan Meyer fuel cell, the hydrogen generation unit can be a huge capacitor?  The device uses DC and Choke (inductor).  It is possible that the device is using resonance energy to do the electrolysis?
Once we accept that we can bring in electromagnetic energy from the environment into a lead out energy system without violatig the Law of Conservation of Energy, we should start looking at the actual mechanism.  If the Electron Cloud energy comes from the laminated core material, can we use other methods to get it into resonance?  Motionless device better than the QEG is definitely possible.
Divine Guidance?
ltseung888
There were comments that the same axle makes the two unbalanced wheels of Yuen Wheel too balanced.  The suggestion is to have a belt mechanism in between.
Please keep such good suggestions coming.
