0 Members and 25 Guests are viewing this topic.
ltseung888
Analysis of the Christmas Gift
6.   If gravitational energy can be brought in, magnetic or electromagnetic energy must be able to be brought in similarly.  We can replace the pendulum with a magnet or do the equivalent of a horizontal pendulum with magnetic fields.
This shows the true power of a theory.  If the theory is correct, it can project or predict other cases not covered by the initial experiments.  If the Lead-Out Energy Theory is correct, it predicts not only the leading out of gravitational energy.  It also predicts the leading out of magnetic and electromagnetic energies.  That will give solid theoretical ground for research into Pulse Motors, Motionless Flux Change devices etc.
The many devices discussed in the Patrick Kelly Book will see day light.  The obstacle posted by "the Law of Conservation of Energy cannot be violated" is removed.  If we can lead-out or bring-in energy from the surrounding environment, we do not violate this Law.
noonespecial
Quote from: ltseung888 on December 16, 2014, 02:36:41 PM
5.   The Yuen Wheel consists of two or more unbalanced wheels.  Experimenting with the size of the wheel, the magnitude and number of weights on the rim of the wheel is likely to yield the Bessler Wheel which can lead out gravitational energy to rotate for 53 days and do some mechanical work.
The Yuen Wheel is interesting because it has been used to test the various parameters of the unbalanced wheel.  We experimented with the number of weights and their positions on the rim of the bicycle wheel.  We also experimented with one, two, three and four wheels on the same axle.  We shall do some experiments with two axles.
The experimental results so far suggested that the Bessler Wheel may not be a hoax.  We may indeed lead out enough gravitational energy to make the device running forever with some energy to spare.
However, we shall focus on the Chan Wheel first.  The Chan Wheel will provide the necessary scientific data to confirm the lead-out energy theory.  Once the theory is confirmed beyond any shadow of doubt, the rest will be smooth sailing.  One of the most difficult part in measuring the Input Energy of the Milkovic 2SO has been solved in the Chan Wheel.  We measured the drop in potential energy of the weight at the rim.
Some actually argued that the Milkovic 2SO itself is sufficient proof already.  However, we would like to have a working lead-out energy device in our own "laborartory".
I would be interested in seeing one running under load. I have built several 2SO devices and they all ran fine until a load was applied and then they would fail. Please be sure to add this to your testing.
tagor
Quote from: noonespecial on December 16, 2014, 06:21:37 PM
LOL
yes the the 2So ran fine without load ...
I can lift 10000 kilos with one finger ... and a very very very big lever !!
ltseung888
7.   The magnetic or electromagnetic fields can be much more powerful than the gravitational field.  We can change the polarity, the magnitude and the direction of magnetic or electromagnetic fields easily.
This is why the Lead-Out Energy Theory is so important.  Others use the term zero point energy.  We use standard Physics and Mathematics.
noonespecial
Quote from: tagor on December 17, 2014, 12:42:48 AM
LOL
It's not the lever portion that fails but rather the output falls out of resonance with the input driving it. As long as the output load remains within the resonant window it will run. If the load exceeds this window, it will slow down and stop.
