0 Members and 72 Guests are viewing this topic.
ltseung888
My understanding of the Milkovic 2SO as of Jan 6, 2015
1.   In the first stage, it is a pulsed pendulum.  The mathematics shows that for small angles, 2 parts of horizontal energy leads-out 1 part of vertical gravitational energy.
2.   In the second stage, when the Weight W1 is lifted, the amplitude of the swinging pendulum does not decrease.  The energy used to lift the Weight comes from gravity.
3.   The two above mechanisms bring-in gravitational energy.  If we make the assumption that the finger push energy is the INPUT, we have not considered the extra INPUT of lead-out energy.  This extra INPUT is the "free energy".
4.   The lifting of the heavy weight has been considered by many (including myself at one time) as the OUTPUT.  This is incorrect.  In order to repeat the process, the Weight W1 need to raise the pendulum bob back to the original position.  This must be taken into consideration.
5.   In order to get more energy, the pendulum weight has to be higher and the pendulum length needs to be longer.  This make the scaling up very expensive and inefficient.
6.   When the pendulum is replaced by the Unbalanced Wheel (e.g. Chan Wheel), the rotational speed can be increased for a more efficient operation. However, this need to match the oscillation frequency of the lever.  Experimentally, the Chan Wheel can be tuned with different weights and lever arm lengths to get better results.
7.   The Milkovic 2SO and Chan Wheels are interesting as academic research projects as they are overunity and do lead-out gravitational energy.
8.   The more practical devices should lead-out magnetic or electromagnetic energy.  The 225 HP Pulse Motor and other Pulse Motors are examples.
For those who want to have an overunity device to research, build the Chan Wheel. The trolls do not have a Milkovic 2SO or Chan Wheel and claim that there are no OU devices, just ignore them...
Morality Point:
When you have a working OU device, continue your research...  If you do not want to get rude comments, just do not post.  If you are old like me and do not want to carry the limited knowledge to the grave, post.  Argue on the scientific points.
Merg
Veljko Milkovic's Pendulum Pump replica by Milos Regeljac from Despotovo, Serbia
This technical testing was successful in proving that there has been water pressure needed for the irrigation in agriculture.
Designed pump with a pendulum draws water from a well with a depth of 6 meters and throws water at a height of over 6 meters
what makes the height difference of more than 12 meters.
In this way the objective that is being sought in irrigation has been achieved.
Further work on system automation is currently being done.
Date: December 2014
https://www.youtube.com/watch?v=G_1_Yn4Eji8
ltseung888
One comment on why the QEGs do not work as well as the WITTS generator.
It is the conditioning of the core.  If you try to produce a permanent magnet with DC current, you can use different amps.  If you use small amps, you still have a permanent magnet.   If you use larger amps, the result is likely to be very different.
The published QEG may not have conditioned the core to the same extend as WITTS...
There will still be resonance.  (There will be magnetic properties with low amps.)
Morality Point:
Simple replication of a non-optimal device will also produce a non-optimal device.  Try to come up with a possible hypothesis...  Lead-out theory will help QEG research also...  One Chan Wheel will lead-out different amount of energy from another Chan Wheel of same construction if tuned differently...
Should FixtheWorld people disclose what they know and hope others will build on that?  Their relationship with WITTS may not be "on the best" of terms.
MarkE
Quote from: ltseung888 on January 05, 2015, 09:05:42 PM
Morality Point:
No matter what one does, the QEG is just a very inefficient machine.
Morality Point:  Supporting those who scam others out of money while willfully ignoring facts is really little better than what the scammers do.  Why do you support blatant scams Lawrence?
norman6538
merg  what does this water pump prove?
it works but bottom line is what is the input and what is the
output and how does that compare to ordinary water  pumping?
If it takes less work then viola - you have something worth the effort.
Itseung888
The pendulum below starts at 2 oclock and drops past 10 oclock and on
up to noon. How does it fit into your leadout concept?
http://www.youtube.com/watch?v=4FzK2XKQ-74
You can visually see the input and the output that is
greater than the input - no false measurement possibilities.
You can tell that something in the magnets uniuque is happening here
because the pendulum goes up quickly and then drops back
down slowly and stops.
Norman
