ltseung888
Quote from: Merg on February 04, 2015, 10:19:32 AM
Milkovic Pendulum replica by Konstantin Ivanov
Attempt to manufacture a "pendulum Milkovicha" from scrap parts and check the possibility of converting vibrational motions crossbar in rotation (followed by loading on the generator). Primary mayatnik- Dumbbell 3 kg, set top cargo bike frames- 3 kg.
https://www.youtube.com/watch?v=bf3B38bDZb4
This is a typical "replication" mentality.  The replicator does not know the theory.  He just copies or modifies the original device.
If he knows the lead-out energy theory, he would have asked - what is the best way to lead-out the gravitational energy?
He would most probably find the solution in the Unbalanced Wheel or the Unbalanced Cylinder.
It is not too late.  He can use his experience and resources to study the Lead-out energy theory and then use the unbalanced Wheel or Unbalanced Cylinder...
ltseung888
Quote from: noonespecial on February 03, 2015, 08:00:30 AM
ARMCORTEX speaks for himself only.
I'm currently involved in a collaborative effort and wouldn't have the time anyway.
I have now watched your many videos on youtube.  Your workmanship is first class.  Once you are aware of the power of the Unbalanced Wheel and the Unbalanced Cylinder, you will find a way to incorporate it into your work.
There is and there will be no patent on the Unbalanced Wheel or the Unbalanced Cylinder.  Just develop them to benefit mankind.
noonespecial
Thank you Lawrence, you are very kind.
What you haven't seen of course, is the many, many failed attempts :) but I do sincerely appreciate your kind words.
Like you, I believe that the answer will be found in an unbalanced rotor operating within an overall balanced environment (i.e. - think about Skinner, Kanarev, Bobby etc.)
Best regards,
Charlie
ARMCORTEX
Ok so now, LTseung you know why I say you must find financing.
I say, its a group effort, I done my part, now I need people to di their part and give me $, to charlie as well.
A few oscillator ideas I wanna try on a specially design test right.
Charlie, you are uncertain of that, all those are as of yet not engineering worthy and unproven.
We may need to innovate our thinking here, even tho we have been doing that. we need to see things
even more clearly.  And that there are a few false paths here, troublesome .
ARMCORTEX
On a side note,
the thing wheel, tell the creator to try flexible coupling or joint arm as a main shaft, between the wheels themselves.
3 wobbling wheels on a snake like body.
perhaps theres a material that has some inherant flexibility?
