ltseung888
Quote from: ltseung888 on February 14, 2015, 06:39:32 PM
I shall modify the Chas Campbell device according to the Lead-out Energy Theory.
I believe that he got his device via tinkering.  He could have produced the unbalancing effect via poor machining or belt shaking.
The attached diagram shows the possible modification.  The important part is actually the Unbalanced Wheel or Cylinder mounted vertically.
The configuration is then closer to the Tsinghua University Energy Multiplier...
I am going to take a shot on specifying the Unbalanced Cylinder.  The outer diameter will be 30 cm.  The cylinder height will be 20 cm.  The total weight will be 10 Kg.  The unbalanced bar will be 2 kg.
I do not have any magic formula yet.  The above suggestion is "a shot in the dark".
Morality Point:
When the theory cannot predict the exact dimensions, spend resources on experiments.  Every experiment will provide more data.  If every step in the dark is charted, even the blind will find the way...
The "state secrets" of China and USA may already have all the data.
noonespecial
Why do you say that it must be mounted vertically? Is there some reason why horizontally mounted wouldn't work? Just curious.
ltseung888
For pure gravitational lead-out energy devices, the oscillation comes from the jumping effect.  Or we can think of the Centrifugal force in an Unbalanced Wheel.  That force will change the effective force downwards simulating the jumping action.
If mounted horizontally, the centrifugal force will be horizontal and no jumping action will result.
(The Liang car was reported to lose power rapidly going up an incline.)
noonespecial
Quote from: ltseung888 on February 15, 2015, 12:43:54 AM
I guess that's where my confusion come in. If these cylinders are mounted in fixed bearings, where will the 'jumping action' come from?
Low-Q
This is what you try to accomplish:
