ltseung888
Quote from: webby1 on May 16, 2015, 10:41:03 AM
CF is no different when using only a donut than when using an arm with a pivot,, play with it yourself and you will see that.
There is another much more involved thread that covers this exact idea,, I read that one a while ago,, I forget where it was posted but it was interesting.
So you told me what I did wrong without actually telling me what I did wrong,, and by the way the cart would spin around the hoola-a-hoop a few times after the pulse.
So where are the force vectors for the walls of your donut??
Where is the CP and what is the changing direction and level of that??
What happens if there is a vertical displacement of the magnet within the donut?
So where is the something "NEW"??
Let us focus on the pulsing or energy supply mechanism.
This can be a coil with 500 turns of thick copper wire.  Pulse DC current will temporally
turn it into an electromagnet.  Assume that the permanent magnet (PM) is stationary with the S pole closer to this coil.  The electromagnet will attract the PM with its N pole.  As soon as the PM passes through the middle of the coil, the current is turned off.  This will prevent the PM from attracted back by the coil.
The pulsing force should be strong enough so that the PM rotates at least 3 turns.  The pulsing can be set up so that each time the PM approaches, an additional pulse is provided.  This can get the PM to have a very high angular velocity.  There should be a detection mechanism, a switch-on and a switch-off mechanism.  The duration of pulse will vary with the angular velocity of the PM.
The key factors in providing the pulsing are the DC voltage/current, the number of turns of the coil and the timing and Duration of the pulse.  The coils should be wound tightly around the donut tube,  A pivot arm mechanism cannot do that.
The energy take-out mechanism will be discussed in a separate post.
I shall pause for 5 days for useful comments before continuing.  (Time for a relaxing fishing holiday.)
Lawrence
reply 3156
ltseung888
It looks like that not many people are posting comments in the last 5 days.
The design is improved to add
1.  The importance of detecting the position of the permanent magnet.
2.  Turning on and turning off of the DC pulse current.
3.  The details of the energy giving pulse coil and the energy take-out coil.
More discussions will follow.
Lawrence
repy 3156
ltseung888
The following two pdf files have been taken to Beijing by Mr. Peter Chan, the builder of the Chan Wheel.  The purpose is to sense whether the Chinese Government will encourage or discourage the development of the lead-out energy flying saucer by private entities.
If the Chinese Government encourages such development, there is strong possibility of raising enough funds in Hong Kong to do the research and development.  Products will follow.
If the Chinese Government discourages such development, the likely scenario is for some other Nation to take it up.
The fifth design is simple enough for the top universities and companies to understand.
Divine Wine is for all to share...
Lawrence
reply 3156
ltseung888
One possible bonus.
In the fifth design, there are elements of the pulse motor.  Most pulse motors drive the wheel and take-out the energy with coils at an angle.  Furthermore, the different permanent magnets are fixed in relative position: the rotational speed of these permanent magnets are all the same.
The pulse wheels can lead-out gravitational and electromagnetic energy.  The most powerful example is the 225 HP Pulse motor.
It is quite possible - the fifth design is already a lead-out energy device...
The new paradigm of our flying anywhere using lead-out energy including outer space is coming.  The lead-out energy is likely to be the electron cloud or electron motion energy already present in the magnetic materials.
Will USA and China disclose the top secrets?
Lawrence
reply 3156
ltseung888
One possible variation.
The donut shaped tube can be replaced by a circular track as shown.
What is the best way to circulate the information and benefit the World?
